Medical Understanding the Bragg-Gray Theory and its Application in Radiophysics
  • Thread starter Thread starter AgusCF
The discussion centers around the Bragg-Gray theory and its application in calculating dose in water for 45 MV using both the Bragg-Gray cavity method and the equation for electronic equilibrium. The initial query raised concerns about obtaining similar results from both methods, despite expectations of significant differences. Clarifications were made regarding the Bragg-Gray theory, which relies on the assumption of charged particle equilibrium in a small cavity within a medium, where ionization is proportional to absorbed dose and does not alter the radiation's spectral characteristics. The conclusion reached indicates that charged particle equilibrium is less restrictive at lower energies compared to higher energies, which explains the similar results obtained in the calculations.
AgusCF
If I study the dose in water with the Black-Gray cavity and the equation for electronic equilibrium... Why I obtain similar results for the same value of MV? Someone knows? Thanks! [Sorry for my english :( ]
Biology news on Phys.org
Your mean Bragg-Gray don't you? Could you please elaborate on your issue? Your question does not make sense as stated,
Likes AgusCF
Yes, sorry, Bragg- Gray. I mean (as exercise) I calculate the dose in water for 45 MV by Bragg-Gray cavity and by the equation for electronic equilibrium (i do not know its proper name) and I obtained similar values. My question is: Why? I thought that i must obtain very diferent values.
Thanks!
Bragg Gray Theory assumes that charged particle equilibrium exists at the position of a small cavity in a medium , that the ionization produced in the cavity is proportional to the absorbed dose and that the cavity does not significantly change the spectral characteristics of the ionizing radiation at the cavity position.
Likes AgusCF
Well I found the answer. It seems that the charged particle equilibrium it is not a restrictive condition; particulary at low energies is less restrictive than at high energies.
Thanks for your aid!
https://www.discovermagazine.com/the-deadliest-spider-in-the-world-ends-lives-in-hours-but-its-venom-may-inspire-medical-miracles-48107 https://en.wikipedia.org/wiki/Versutoxin#Mechanism_behind_Neurotoxic_Properties https://www.sciencedirect.com/science/article/abs/pii/S0028390817301557 (subscription or purchase requred) he structure of versutoxin (δ-atracotoxin-Hv1) provides insights into the binding of site 3 neurotoxins to the voltage-gated sodium channel...
Popular article referring to the BA.2 variant: Popular article: (many words, little data) https://www.cnn.com/2022/02/17/health/ba-2-covid-severity/index.html Preprint article referring to the BA.2 variant: Preprint article: (At 52 pages, too many words!) https://www.biorxiv.org/content/10.1101/2022.02.14.480335v1.full.pdf [edited 1hr. after posting: Added preprint Abstract] Cheers, Tom
