Radius of Circular Track: Solve for 745m & 475°
  • Thread starter Thread starter DOA_Kasumi22
    Radius Track
To find the radius of a circular track where a car travels 745 m through an angle of 475°, the relationship between the arc length and the circumference is crucial. The formula C/745 = 360°/475° can be used to calculate the total circumference C. Once C is determined, the radius can be found using the formula C = 2πr. The discussion highlights the importance of understanding the proportionality between arc length and angle in circular motion. This problem is essential for completing the homework assignment before the deadline.
DOA_Kasumi22
A car travels a distance of 745 m along a circular track, and the driver finds that she has traveled through an angle of 475°. What is the radius of the track?
None that I know. The only thing I know is that the track is circular
I used an example in my texbook which was identical to this one except the distance was 750 m and the angle was 450.
First I :
750/4=187.5( The 4 is from the 4 different quadrants)
Then I:
187.5/2=93.75------>94m
The solution in the back of the book said that the answer was 95 m but I'm not to sure if this is the right procedure.
This is the last homework problem that I have to complete before I turn it in before midnight.
You need to know that the length of the arc of a circle is proportional to the angle.
360° corresponds to the total circumference C of the circle. 475° angle corresponds to 745 m, so C/745=360°/475°. Calculate C. How is the circumference related to the radius?
ehild
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
