Can We Calculate Ramjet Thrust Using Combustion Mach Number and Rayleigh Flow?
Calculating ramjet thrust involves understanding the combustion Mach number and its relationship with ambient conditions such as free stream Mach number and pressure. The thrust can be derived by analyzing the stagnation temperature ratio between the inlet and combustor exit. Incorporating the combustion Mach number is essential for accurate thrust calculations, and Rayleigh flow considerations may also play a role in the analysis. The discussion seeks additional insights or recent findings to enhance the understanding of these calculations. Overall, a comprehensive approach is necessary to effectively calculate ramjet thrust.
tomliu93
For a ramjet engine, combustion occurs at a finite Mach number M. If we know the ambient conditions like free stream Mach number and pressure and the ratio between the stagnation temperature at the inlet and exit of the combustor, how can we derive the thrust? How can we incorporate the combustion Mach number into calculation? Do we need to consider Rayleigh flow?
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
