What is the speed of an athlete landing in a long jump with known range, angle, and height?
  • Thread starter Thread starter zman2011
    Formula Range
To determine the landing speed of an athlete in a long jump, the problem involves a launch angle of 25 degrees and a horizontal distance of 8.5 meters, with both launch and landing heights at 0 meters. The range formula can be used to isolate the initial velocity, but it may involve complex algebra. An alternative approach is to apply standard kinematic equations for both the x-axis and y-axis motions, allowing for two equations with two unknowns: velocity and time. This method may simplify the calculations compared to using the range formula directly. Ultimately, the focus is on finding the athlete's landing speed using these physics principles.
zman2011
During a high school track meet, an athlete performing the long jump runs and leaps at an angle of 25 degrees and lands in a sand pit 8.5 m from his launching point. If the launch point and landing point are at the same height, y=0m, with what apeed does the athlete land?
How do i use range formula to find initial velocity
The range formula is kind of specialized to give you range if you know V, θ, and y(0). Since you know range, θ, and y(0) you could isolate v, I suppose. The algebra looks painful too me. I'd rather find v using standard kinematic equations for x-axis motion and y-axis motion--2 equations, 2 unknowns (v and T).
