Rank Pendulums Based on Max Speed
  • Thread starter Thread starter Duckboy
    Max Speed
The discussion focuses on ranking pendulums based on their maximum speeds, derived from the conservation of mechanical energy principle. The key equation used is v = √(2gΔh), where v is the maximum speed, g is gravitational acceleration, and Δh is the height from which the pendulum is released. It is clarified that mass does not affect the speed, as it cancels out in the energy equations. Participants confirm that the maximum speed depends solely on the height of release and local gravitational acceleration. The conclusion emphasizes that some pendulums may have equal maximum speeds based on these factors.
Duckboy
Rank each pendulum on the basis of its maximum speed.
http://img148.imageshack.us/img148/9674/picture3op6.png
m*g*\Delta = 1/2*m*v^{2}
At first I thought that all the Max speeds were the same, but I was wrong.
I know that the kinetic energy is equal to the change in potential energy since I solve the first 2 parts correctly.
If I follow the equation, I know the mass will cancel out. So am I solving for v^{2}?
So if I simplify the equation is it:
v = \sqrt{2*g*\Deltah}
Then would i just apply it to all the situations?
Thanks
Sorry for the bad format for the equations.
Yes, you have the important part right here. We assume that the mechanical energy, E = K + U (kinetic+potential energy) is conserved in the pendulum swing, because gravity is a conservative force and we ignore air resistance and friction in the bearing the pendulum swings on.
So when the pendulum is initially released, all of the mechanical energy is in gravitational potential energy (relative to the bottom of the swing), all of which is converted into kinetic energy when the pendulum reaches the bottom. This let's you write the equation above.
You solved this for v^2 = 2gh correctly. So this tells you that in an entirely gravitational process of this sort, the mass is irrelevant and that the speed at the bottom of the swing will depend only on the local gravitational acceleration and the height of release of the pendulum bob. (Thus, in sorting your examples, some will be of equal rank!)
Thanks! I just needed to be sure.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
