Rank the velocities of the balls
  • Thread starter Thread starter omc1
    Balls rank
The discussion revolves around ranking the final velocities of various masses in an elastic collision scenario. Participants emphasize the importance of the conservation of momentum, noting that the total momentum of the system must remain zero before and after the collision. There is confusion regarding why the heaviest mass does not necessarily have the highest final velocity, with explanations suggesting that lighter masses are more easily influenced during collisions. The conversation highlights the need to apply generic equations for elastic collisions to analyze the outcomes effectively. Understanding these principles is crucial for solving the problem accurately.
omc1
Small masses m1 (m1 = 30 kg) and m2 (m2A = 5 kg; m2B = 10 kg; m2C = 40 kg; m2D = 50 kg; m2E = 30 kg) are each attached to a string of length 2.0 m. The other end of each string is attached to a common point on the ceiling. The masses are raised until each string is at an angle of 22o with respect to vertical, and then simultaneously released. They collide elastically when the strings are vertical. For each case, rank the final velocity of m2, from smallest to largest.
using the elastic equation formula
i don't understand y the heaviest one wouldn't be going the fastest...
You just need to write generic equations for an elastic collision and then plug in the masses for each case.
The heaviest one is the one most difficult to influence - whereas the lightest one is the easiest. Or what happens if you roll 2 marbles of different weights together?
I think this assignment has to do with the law of conservation of momentum.
If you release all the balls at an angle, by the time they're about to collide, the system has a total momentum of 0, and after the collision has happened it will need to stay that way.
oh ok I see that analogy explains it better...i will work on that and see what I get. thanks
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
23K
