Rate of heat transfer / specific heat
The discussion focuses on calculating the time required to heat a concrete slab, specifically one that is 8 inches thick with an initial temperature of 60°F and ambient air temperature of 20°F. The thermal conductivity (k) of concrete is 1.7 W/m·K, and its specific heat capacity (c) is 750 Joules. The rate of heat transfer is defined by the equation H = -k A (dT / dX), while the heat transfer over time is calculated using dQ = m c dT. The conclusion indicates that it would take approximately 10,000 seconds, or several hours, to heat the slab significantly.
  • Understanding of thermodynamics principles
  • Familiarity with heat transfer equations
  • Knowledge of thermal conductivity and specific heat capacity
  • Basic calculus for integral applications
  • Research thermal diffusivity calculations in materials
  • Learn about heat transfer coefficients in different materials
  • Explore numerical methods for solving heat transfer problems
  • Study the effects of insulation on heat transfer rates
Engineers, physicists, and students studying thermodynamics or heat transfer, particularly those involved in building design and material science.
charlotte7070
I am digging back thorugh thermodynamics textbooks, and am seeing insulation values etc. but none on how to solve for time required to heat a material.
Here is the specific problem. I am trying to fgure out how long its takes to cool (or alternately heat) a concrete slab.
The slab is 8 in. with initial temp 60 degrees F. Temperature on top and bottom of slab is ambient air temp, 20 degrees.
k, concrete = 1.7 W / m - deg K
c, concrete = 750 Joules
the area of slab can be assumed to be very large (an acre? infinity?)
and the air can be assumed to not change as a result of the heat loss of the concrete.
So I have rate of heat transfer: dependent on the surface area,
H = -k A (dT / dX)
and specific heat of concrete, dependent on mass:
dQ = m c dT = Joules
t (seconds) to cool one inch thickness concrete by 22.2 deg C or K
= dQ / H = 637 seconds (this seems a little fast to me since concrete is fairly insulating material).
Does this look correct? (Assuming I have the heat capacity and conductivity of concrete correct). This would be derived into an integral to get the temp at a certain time and depth, but as a consultant would be laughed out of the room, and will simplify to some finite steps in time and thickness.
No need to get to technical! I won't get it! Thank you for your input.
Science news on Phys.org
Hi charlotte7070, welcome to PF. A good rule of thumb for characteristic heat diffusion times is [itex]t\approx L^2/D[/itex], where L is a characteristic length (I'd take 4 in, or 0.1 m, for this problem) and [itex]D=k/c\rho[/itex] is the thermal diffusivity, which looks like it's around 10-6 m2 s-1 for concrete. So I'd estimate it would take at least 104 s, or several hours, to heat most of the slab to close to 60°F.
thank YOU!
  • · Replies 27 ·
