Ratio of Inertia for Two Disks with Different Thicknesses
  • Thread starter Thread starter plus1
    Inertia Ratio
plus1
Two disks have the same radius R and the same mass M, but one of the disks is twice as thick as the other. Disk A has thickness t, and disk B has thickness 2t. How does the moment-of-inertia of disk A about an axis through the center compare to that of disk B? Specifically, what is the ratio I_A / I_B ?
above
The moment of inertia of a disk is I=1/2MR^2 but I don't understand where the thickness would be. If the thickness has no significance in the equation then would ratio be 1:1
What's the moment of inertia of a cylinder compared to that of a disk?
There are three axes through the center (actually an infinite number).
The moment of inertia for the axis perpendicular to the base(s) of the cylinder (disc) does not depend on the thickness.The other ones do.
But I suppose the problem assumes the simplest case, right?
isn't the moment of inertia of a solid cylinder the same as that of a disk? i looked it up in my physics book and it gave the moment of inertia as 1/2MR^2 for a disk.
since the moment of inertia doesn't depend on thickness, the ratio of the two disks would be 1:1, right? that was my first guess but wasn't sure.
Exactly, assuming--as nasu points out--that we are talking about an axis perpendicular to the center of the disk. (Which is the simplest case.)
My reason for bringing up the cylinder was so that you didn't have to guess. :wink:
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
