Inconclusive Results When p=1: Exploring Uk Series
  • Thread starter foo9008
  • Tags
    Series Uk
In summary: The ration ##\rho## is defined by ##\rho=\displaystyle \lim_{n \rightarrow \infty}\frac{|u_{n+1}|}{|u_n|}##.##\rho=1## doesn't mean that ##\frac{|u_{n+1}|}{|u_n|}=1## for some (or all) ##n##, but that the limit of these ratio's is...the limit of these ratio's is 1.
foo9008
678
when the test is inconclusive when p = 1? when p=1 , the sum of uk will grow bigger , to infinity , right ?
let's say uk = 2 , uk_2 = 2 , so as uk_3 ,l uk_4 ... the sum of all of them will beocme infinity , right?[/B]
When p=1, the test is inconclusive, meaning that the series may or may not converge.
Your example indeed diverges.
What about the series defined by ##v_n=\frac{1}{n²}## (for ##n \in \mathbb N,\ n\neq 0##)?
it will diverge , right ? why it is said to be inconclusive ?
foo9008 said:
it will converge , right ? why it is said to be inconclusive ?
Yes, it will converge.
This shows that ##\rho =1## doesn't tell you anything about convergence or not of the series.
Your series ##u_n## has a ratio ##\rho =1##, and diverges.
My series ##v_n## has a ratio ##\rho =1##, and converges.
That is what is meant with inconclusive: when ##\rho =1##, you have to find another method to determine whether the series converges or diverges.
sorry , i made a typo in the previous post , i mean it will DIVERGE , let's say we have 1/ (100^2) , we have 200 terms of 1/ (100^2) , we will get sum of them = 0.02 , if there are 300 of them , we will get 0.03 ...
No, it really converges.
If you take the partial sum up to some number ##N##, you will indeed see that:
##\displaystyle \sum_{n=1}^N \frac{1}{n²} \geq \sum_{n=1}^N \frac{1}{N²} =\frac{N}{N²}=\frac{1}{N}##.
But why would that imply divergence?
(See @Ray Vickson post about the proof that the series converges.)
For the harmonic series, you can group the terms in such a way that it follows that the limit of the partial sums is +∞. (See @stevendaryl 's post.)
You can't do this with this series.
why the small n is replaced by big N ? they are not the same , right ? the sum of them should be N(1/n^2) , right ?
foo9008 said:
what do u mean by small n and BIG N ? what's the difference ?
##N## represent a fixed, chosen number, like you chose 200 or 300 in post #5.
##n## is the summation index.
##\displaystyle \sum_{n=1}^N \frac{1}{n²}=\frac{1}{1}+\frac{1}{2²}+\frac{1}{3²}+\dots +\frac{1}{(N-1)²}+\frac{1}{N²}##
If N=300, then
##\displaystyle \sum_{n=1}^N \frac{1}{n²}=\sum_{n=1}^{300} \frac{1}{n²}=\frac{1}{1}+\frac{1}{2²}+\frac{1}{3²}+\dots +\frac{1}{299²}+\frac{1}{300²}##
N is a fixed number that is reasonably large. n is the index on the summation, taking on the values 1, 2, 3, ..., up to N.
Also, "text-speak" such as "u" for "you" isn't allowed on this forum.
If N=300, then
why the n inside the (1/n^2) not a fixed number? since we have p (ratio) =1
Why should it?
The ##n## is not fixed, it is the summation index in ##\displaystyle \sum_{n=1}^{\infty}u_n##.
##\rho=1## doesn't mean that ##\frac{|u_{n+1}|}{|u_n|}=1## for some (or all) ##n##, but that the limit of these ratio's is 1.
n isn't fixed -- the exponent 2 is fixed. p is not the ratio in the Ratio Test -- it's the exponent in ##\frac 1 {n^p}##.
Please take more time to read these tests more carefully.
1. What does it mean when p=1 in a scientific study?
When p=1 in a scientific study, it means that the results were not statistically significant. This means that there is no strong evidence to support the hypothesis being tested. It could also mean that there was a flaw in the study design or data collection, or that the sample size was too small to detect a meaningful difference.
2. How does having an inconclusive result affect the validity of a study?
Having an inconclusive result can significantly affect the validity of a study. It suggests that the results may not be reliable or accurate. This can be due to various factors such as bias, confounding variables, or limitations in the study design. It is important for scientists to acknowledge and address inconclusive results in order to maintain the integrity of their research.
3. Can inconclusive results be considered as evidence?
Inconclusive results cannot be considered as strong evidence to support a hypothesis. However, they can still provide valuable insights and information for further research. It is important for scientists to accurately report and interpret inconclusive results in order to contribute to the overall body of scientific knowledge.
4. How can scientists prevent getting inconclusive results in their studies?
To prevent getting inconclusive results, scientists should carefully plan and design their studies, including selecting an appropriate sample size, controlling for confounding variables, and using reliable methods for data collection and analysis. It is also important for scientists to consider potential limitations and address them in their research.
5. How can inconclusive results impact future research in a particular field?
Inconclusive results can impact future research in a particular field by highlighting the need for further investigation. They can also provide a foundation for other scientists to build upon and potentially find more conclusive results. However, if inconclusive results are not properly addressed or interpreted, they can hinder progress in a particular field and lead to misleading conclusions.
