How Does Distance from Earth Affect Gravitational Weight?
In summary, the weight of a person at different distances from the center of Earth can be calculated using ratios. Assuming the person weighs 980N on the surface of Earth, the weight at 128 000km above the surface is approximately 7.32 x 10(-7) N, at 4.5 times the distance from the center is approximately 34.2 x 10(-7) N, and at 745 400km from Earth's center is approximately 1.30 x 10(-7) N.
Rgonzales
For this problem, use ratios only to obtain the weight of a person at the following distances. Assume the person weighs 980N on the surface of Earth.
a) 128 000km above the surface of Earth
b) 4.5 times the distance from the centre of Earth
c) 745 400km from Earths Centre.
[tex] F_{g1} r_1^2 = F_{g2} r_2^2 [/tex]
I am confused of where numbers should go. I assumed [tex] F_{g1} [/tex] to be 980N,
[tex] r_1^2 [/tex] to be the radius of the Earth of 6.38 x 10(to the power of 6), [tex] r_2^2 [/tex] to be 128 000 km and [tex] F_{g2} [/tex] to be the missing variable. Yet, i did not manage to find the answer. Please help me out.
a) 128 000km above the surface of Earth F_{g1} (6.38 x 10(to the power of 6)) = F_{g2} (128 000 + 6.38 x 10(to the power of 6))980N (6.38 x 10(to the power of 6)) = F_{g2} (134.38 x 10(to the power of 6))F_{g2} = 980N/ (134.38 x 10(to the power of 6)) F_{g2} = 7.32 x 10(-7) Nb) 4.5 times the distance from the centre of Earth F_{g1} (6.38 x 10(to the power of 6)) = F_{g2} (4.5 x 6.38 x 10(to the power of 6))980N (6.38 x 10(to the power of 6)) = F_{g2} (28.71 x 10(to the power of 6))F_{g2} = 980N/(28.71 x 10(to the power of 6)) F_{g2} = 34.2 x 10(-7) Nc) 745 400km from Earths Centre F_{g1} (6.38 x 10(to the power of 6)) = F_{g2} (745400 + 6.38 x 10(to the power of 6))980N (6.38 x 10(to the power of 6)) = F_{g2} (751.78 x 10(to the power of 6))F_{g2} = 980N / (751.78 x 10(to the power of 6)) F_{g2} = 1.30 x 10(-7) N
As a scientist, it is important to carefully analyze and understand the problem before attempting to solve it. In this case, we are looking for the weight of a person at different distances from the surface of the Earth, using ratios and the given weight of the person on the surface (980N).
First, let's define the variables we will be using:
F_{g1} = gravitational force at first distance (in this case, on the surface of Earth)
F_{g2} = gravitational force at second distance
r_1 = radius of Earth (6.38 x 10^6 m)
r_2 = distance from Earth's center
Now, we can use the gravitational force equation:
F_{g1} = F_{g2} (r_1 / r_2)^2
For part a) 128 000km above the surface of Earth, we can calculate the distance from Earth's center using the given radius of Earth (6.38 x 10^6 m) and the given distance (128 000 km = 128 000 000 m).
r_2 = r_1 + 128 000 000 = 6.38 x 10^6 + 1.28 x 10^8 = 1.34 x 10^8 m
Plugging this into the equation, we get:
980N = F_{g2} (6.38 x 10^6 / 1.34 x 10^8)^2
Solving for F_{g2}, we get:
F_{g2} = 980N * (1.34 x 10^8 / 6.38 x 10^6)^2 = 98N
Therefore, the weight of the person at 128 000km above the surface of Earth is 98N.
For part b) 4.5 times the distance from the center of Earth, we can use the same process to calculate the distance from Earth's center:
r_2 = 4.5 * r_1 = 4.5 * 6.38 x 10^6 = 2.87 x 10^7 m
980N = F_{g2} (6.38 x 10^6 / 2.87 x 10^7)^2
1. What is the definition of gravity?
Gravity is a fundamental force of nature that causes objects with mass to attract each other. It is responsible for keeping planets in orbit around the sun and objects on Earth from floating away into space.
2. How is gravity measured?
Gravity is measured using an instrument called a gravimeter, which detects the gravitational pull of an object. The unit of measurement for gravity is meters per second squared (m/s²).
3. How does gravity affect objects of different masses?
Gravity affects all objects equally, regardless of their mass. However, the force of gravity is stronger on objects with larger masses, which is why larger objects like planets have a stronger gravitational pull than smaller objects like rocks.
4. Can gravity be manipulated or controlled?
No, gravity is a natural force that cannot be manipulated or controlled. However, its effects can be counteracted by other forces, such as the thrust of a rocket or the lift of an airplane.
5. How does the ratio involving gravity affect objects in motion?
The ratio involving gravity, also known as the gravitational constant, determines the strength of the gravitational force between two objects. This force affects the motion of objects by causing them to accelerate towards each other. The greater the mass of the objects, the stronger the gravitational force and the greater the acceleration.
