RC car electric start simple circuit
A communications electrician in the Navy is attempting to build a simple electric starting circuit for a Nitro Methane RC car using a 4.8v, 600mAh NiCd battery and a servo-operated micro switch. The circuit design includes branches for powering the starting motor and an ignitor, which requires careful voltage regulation. The user seeks advice on the appropriate resistor sizes needed for the ignitor, specifically questioning whether one resistor is sufficient or if a second is needed. Despite having prior electronics experience, the user has faced challenges and is looking for more detailed guidance, including circuit diagrams and measurements. The discussion emphasizes the need for community input to resolve these technical issues.
sailinghickey
I'm a communications electrician in the Navy. I went through some electronics theory about eight years ago. Now, I'm trying to build a simple circuit for an on-board electric starting system. The vehicle runs on a small Nitro Methane motor and uses a glow plug for the ignition. I'm using a rechargable 4.8v, 600mAh NiCd connected to a servo operated micro switch. From there, the circuit branches into parallell. One branch is unregulated to power the starting motor. the other branch powers the ignitor. The ignitor can only handle 1.3v.
1) What size resistor or resistors do I need to use in this system? I know one has to go before the annode of the ignitor.
2) Do I need to have a second resistor going into the cathode side as well?
Do you guys need more info or pictures? I noticed over 80 people have looked at this. Yet, no one has posted a reply. I've been trying to build the circuit through trial and error. No luck yet though.
You need to post circuits, pictures and current and voltage measurements as well as a full description of what you are trying to do.
You have some electronics experience, so you should be able to gather much of this information.
Then it would help if you could say what you have already tried.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
