Calculating Resistance in an RC Circuit: A Time Constant Conundrum
In an RC circuit with a 5 microfarad capacitor, a resistor, and a 12VDC battery, the time constant is given as 4.0 seconds. The resistance can be calculated using the formula R = τ/C, resulting in a value of 800,000 ohms, which is valid despite initial expectations of a smaller number. The maximum charge on the capacitor can be determined as it approaches its limit over time, typically reached after about five time constants. Additionally, the charge remaining on one plate after one time constant can be calculated using the charge function q(t) evaluated at that time. The discussion confirms the accuracy of these calculations and the understanding of circuit behavior.
QuarkCharmer
A 5 micro farad capacitor is in series with a resistor, a switch, and a 12VDC ideal battery. The switch is closed at t=0s. The time constant of the circuit is 4.0s.
Determine the value of the resistance R?
From another example of a series circuit with a resistor and cap and switch, we found the equation:
q(t) = CE(1-e^{\frac{-t}{\tau}})
where tau is the time constant, and is substituted for RC in the equation. Now to me, this seems simple, tau = RC...
so R = \frac{\tau}{5.0*10^{-6}}
where tau = 4.0 seconds
which is like 800,000 \Omega, which cannot be right! How do I tackle this problem?
There's nothing wrong with 800 kΩ for a resistor value. Heck, it's less than a megohm!
Really? I was expecting a much smaller number so I thought I was wrong. Thank you.
The other parts of the problem ask for the max charge on the cap. Which is simply the lim as t goes to infinity, but we were told a rule of thumb is that the cap is fully charged when about 5 time constants have passed.
Then the next part asks the charge remaining on one plate after one time constant. Wouldn't that simply be the function q(t) evaluated at one time constant? The charge on one plate of the cap would just be negative the charge of the other right?
You're welcome.
Yup, that's a handy rule of thumb. After five time constants the circuit conditions should reach about 99.3% of their final values.
Yes and yes.
Thanks!
