RC Filtering Circuits: Terminals, Vin, Vout & Ground Explained
  • Thread starter Thread starter Stickybees
    Circuits Rc
In RC filtering circuits, the top terminals represent the input (Vin) and output (Vout) voltages, while the bottom terminals serve as return paths for the circuit. Vin is measured across the left two terminals, and Vout is measured across the right two terminals. To measure voltage, connect the red probe to the top terminal and the black probe to the corresponding bottom terminal. Understanding these terminal functions is crucial for accurate measurements in lab practicals. This knowledge will aid in effectively analyzing RC circuits during experiments.
Stickybees
Heya! I've got a lab practical tomorrow to do with RC circuits, what do the terminals at the top and bottom of a filter circuit diagram mean, I'm assuming Vin and Vout is the voltage in and then 0V/ground, but what do the bottom two terminals correspond to?
Cheers
Cheers
The bottom left and right are the return only. V_{in}\; is input voltage across the left two terminals from the top terminal to the bottom terminal on the left. V_{out}\; is the output voltage across the right two terminals from the top terminal to the bottom terminal on the right.
Remember when you measure voltage, you need to measure between two terminals. You put the red probe on the top terminal and the black probe on the bottom terminal. Hope that help.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
