Re-arranging a formula to find Vm
  • Thread starter Thread starter Sparkyian
    Formula
To rearrange the formula V(L) = V(m) - (V(m)/2fCR) to find V(m), start by multiplying both sides by 2fCR to eliminate the fraction. Next, isolate V(m) by moving all terms involving V(m) to one side of the equation and the constants to the other side. Continue simplifying and combining like terms until you arrive at the final form of V(m). The process primarily involves basic algebraic manipulation. Following these steps will yield the desired expression for V(m).
Sparkyian
Can anyone explain to me how to re-arrange the following formula to find V(m).
V(L)=V(m)-(V(m)/2fCR).
Please explain step by step as I am really stuck.
Thank you.
It's just algebra. Start by multiplying both sides by 2fCR in order to get rid of the fraction. Then isolate Vm by putting all of the terms with Vm on one side, and all of the terms without Vm on the other side. Continue collecting terms and stuff until you're left with something of the form
Vm = blah.
Thank you.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
