Why Is Capacitor Reactance 1/LC Instead of 1/sqrt(LC)?
  • Thread starter Thread starter ben.tien
    Reactance
The reactance of a capacitor is defined as 1/(2πfC), not 1/LC or 1/√(LC). This formula arises from the relationship between frequency and capacitance in AC circuits. When analyzing units, capacitance is expressed in Coulombs per volt, leading to the conclusion that reactance has units of ohms. The discussion clarifies that the correct formulation for capacitive reactance incorporates frequency, emphasizing the importance of understanding complex impedance. Overall, the confusion stems from misinterpretation of the reactance formula in relation to frequency and capacitance.
ben.tien
I just want to know why the reactance of a capacitor is 1/LC rather than 1/\sqrt{}LC?
2(pi)f = 1/sqrt(LC)
It's not. The magnitude of the reactance of a capacitor C is 1/(2πfC). Or, treating it as a complex impedance, the impedance is 1/(j2πfC).
yeah my bad why is it that instead of 1/((2pif)^2)C)
You can do a unit analysis. Capacitance is Coulombs per volt. So, ignoring unitless constants,
1/(f*C) ==> [T][V]/[Q]
but amps is charge per unit time, or [A] = [Q]/[T], so our units become
[T][V]/[Q] ==> [V]/[A] ==> Ohms.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
