Real Analysis - Differentiation in R^n - Example of a specific function
GridironCPJ
Give an example of a continuous function f:R^2→R having partial derivatives at (0,0) with
f_1 (0,0)≠0,f_2 (0,0)≠0
But the vector (f_1 (0,0),f_2 (0,0)) does not point in the direction of maximal change, even though there is such a direction.
(If this is too difficult to read, please see the PDF for a nicer version)
Note that this is a problem from TBB's Elementary Real Analysis
none
I have no idea how to attempt the construction of such a function. Any tips, suggestions, or a walkthrough of how to find such a function would be greatly appreciated. If you feel like giving me an answer, please explain it because understanding this is the most important part of this.
I think you've recognized that this problem has you finding a "counterexample" to a well-known theorem in multivariate calc (it's not really a counterexample to the the theorem, because the theorem is true). If I were you, I would look carefully at the statement and proof of that theorem to see what conditions a function needs to satisfy in order for the theorem to apply. Then try to construct a function that doesn't have the necessary qualities.
Also, the fact that the problem doesn't use the word "gradient" may be a hint.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
