Really quick question about entropy
  • Thread starter Thread starter proton
    Entropy
When two systems, A and B, come into contact, the total number of accessible microstates for the combined system is given by the product of their individual states, (W_A)(W_B). This relationship holds true in nonequilibrium situations, where the net entropy must either remain constant or increase, aligning with the second law of thermodynamics. The discussion highlights the importance of clearly articulating questions in physics for better understanding. It also touches on the zeroth law of thermodynamics, which relates to thermal equilibrium among systems. Overall, clarity in presenting questions is emphasized for effective communication in scientific discussions.
proton
My question may be kind of a dumb question, but I tried searching for the explanation online and in my crappy textbook and my lecture notes are kinda unclear.
Consider 2 systems, A and B, that are brought into contact with each other, with accessible states W_A and W_B, respectively. After contact, the combined system then has (W_A)(W_B). Now, is this true for equilibrium and/or nonequilibrium?
My guess is that its at nonequilibrium because the net entropy must remain the same or increase, which leads to the 2nd law of thermodynamics
you actually may try the zeorth law of themodynamics whichstates that if a system a is i themal equilibrium with a system b and system b is in thermal equi. with system c then and c are also in thermal equi.
i may have ans. your ques. wrong as it is unclesr to me
present quesstion in clear way
in above sentences :smile:your confused me atAfter contact, the combined system then has (W_A)(W_B). in physics you must represent question in clear way to proper understading OK:smile::smile::smile:
Ok, after systems A and B are brought into contact, the total number of microstates in the combined system consisting of systems A and B, is equal to (W_A)*(W_B)
