Rearranging equations - is this correct?
  • Thread starter Thread starter Lucy573
To rearrange the equation F=Kq1q2/r^2 to make K the subject, the correct formula is K=Fr^2/q1q2. The original poster expressed uncertainty about their solution but received confirmation that it was correct. They were encouraged to verify their answer by substituting values for K, q1, q2, and r to check consistency with the calculated force F. This approach reinforces understanding of the relationship between the variables in the equation. Overall, the discussion highlights the importance of confidence in problem-solving and verification through practical examples.
Lucy573
Rearrange F=Kq1q2/r^2 to make K the subject
K=Fr^2/q1q2 - is this correct? Sorry I am new to this! Thanks :)
Yes, that's correct.
Fab thanks - should have more faith!
If you want to check your answer, just make up values for k, q1, q2, and r and find F. Then use that F along with the same values for q1, q2, and r and see if you get what you assigned to k originally.
