Rectangle volume using cross sections
Myhappyending
Cross sections are perpendicular to the x-axis and rectangle has the h=1/2b. The region is bounded by the area y=x^2, x-axis and the line x=3
A=BH
A=B(1/2B)
A=3/2B
V=3/2(x^2-3)
just wondering if this is correct and how would i find where i integrate it to?
Myhappyending said:
A=BH
A=B(1/2B)
A=3/2B
Calculus aside, the last statement is wrong.
And do your problems lie in finding the limits of integration?
Ok so we will be integrating between x=0 and x=3. This is due to the region being bound by x=3 and y=x^2 (where y=0 @ x=0).
Therefore, V = (0∫3)* (x^2)(0.5(x^2)) dx
height (1/2b)-----------------^
base------------------^
-----------------^upper and lower limit of integration
A plain square would be calculated like this:
Therefore, V = (0∫3)* (x^2)(x^2) dx
*This is the format (lower limit∫upper limit)
Hope this helps, if you have a question let me know.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
