Recursive and Explicit Formulas for Sequence 1,-2,3,-4,5: Homework Help
  • Thread starter Twistlock
In summary, the conversation is about finding the recursive and explicit formulas for a given sequence. The explicit formula is ((-1)^n+1)n and the recursive formula involves manipulating the expression for a(n+1) until it depends on a(n) and a(n-1), with the sign of the added one changing depending on whether n is odd or even.
Twistlock
I need to find the recursive and explicit formulas for the sequence 1,-2, 3, -4, 5
Recursive Rule: Fn= Fn-1 + Fn-2
Explicit Rule: position of terms F1, F2, F3,...
I have figured out explicit because its ((-1)^n+1)n
Recursive rule i am having trouble with because its around something like -(Fn-1 +1) or close to that
Let a(n) be nth term. You should be able to say what a(1) is. Now manipulate the expression for a(n+1) until you have a right side that depends of a(n), a(n-1), etc.
the sign of the added one will change depdneding on whether n is odd or even
1. What is a recursive formula?
A recursive formula is a mathematical equation that defines a sequence in terms of its preceding terms. In other words, each term in the sequence is calculated using the previous term(s) in the sequence.
2. What is an explicit formula?
An explicit formula, also known as a closed-form formula, is a mathematical equation that directly calculates the value of a term in a sequence without requiring knowledge of the previous term(s).
3. How do you find the recursive formula for a sequence?
To find the recursive formula for a sequence, you need to identify the pattern or rule that relates each term to the previous term(s). This pattern can then be expressed as an equation, where the term on the left side of the equation is equal to the term on the right side of the equation.
4. How do you find the explicit formula for a sequence?
To find the explicit formula for a sequence, you can use a variety of methods such as using the recursive formula and solving for the nth term, using the general term formula for arithmetic or geometric sequences, or using the summation formula for finite arithmetic or geometric series.
5. How do you use recursive and explicit formulas to solve problems?
Recursive and explicit formulas are used to find the value of a specific term in a sequence, or to generate a list of terms in a sequence. They can be used to solve a variety of problems, such as finding the total number of objects in a growing pattern or determining the value of an investment after a certain number of years.
