Relation between wavefunction of the photon and the Four-potential
The discussion centers on the relationship between the wavefunction of photons and the four-potential in the context of quantum field theory. It emphasizes that photons do not have a well-defined wavefunction and are instead described by Fock space states, with the four-potential quantized as operators acting on these states. The concept of "very dimmed light" is clarified as being better represented by coherent states with small average photon numbers rather than single photons. The photoelectric effect is critiqued as a misleading proof of photon existence, as it can be explained semiclassically without invoking quantization. The conversation highlights the importance of accurate interpretations in quantum optics and the evolution of understanding in the field.
christianpoved
Hey! Maybe this is a "piece of cake" question, but here is the thing, i have the Maxwell equations in the Lorenz gauge are
\begin{array}{c}
\partial_{\mu}\partial^{\mu}A^{\nu}=\mu_{0}j^{\nu}
\end{array}
In vacuum this gets reduced into
\begin{array}{c}
\partial_{\mu}\partial^{\mu}A^{\nu}=0
\end{array}
Also the Klein-Gordon equation says that
\begin{array}{c}
\left(\square-\frac{m^{2}c^{2}}{\hbar^{2}}\right)\psi=0
\end{array}
I guess that for a massless particle this is just
\begin{array}{c}
\square\psi=0
\end{array}
This leads to my question, is there any relation between the wavefunction of the photon and the four-potential?
1. It's the LORENZ gauge (no 't').
2. The wavefunction of the photon is not a well-defined concept.
3. Photons are described by Fock space states, quantizing the 4-potential leads to fields as operators acting on those states.
A photon has no wave function! You cannot apply the single-particle interpretation from non-relativistic quantum theory to relativistic particles. It's totally impossible to do so for massless particles like the photon. There is not even a position operator for a photon!
From the point of view of quantum-field theory classical electromagnetic fields are approximations to coherent photon states which are a superposition of Fock states adding up components from all photon-number states, i.e., for these states the photon number is indetermined but the phase is pretty well determined (there's a Heisenberg uncertainty relation between the phase of the field and the photon number).
For the same reason to introduce the photon concept by "very dimmed light" is misleading and strictly speaking even wrong! "Very dimmed light" is correctly described within QED by a coherent state with very small average (!) photon number or energy. Thus the state mostly consists of the vacuum state.
Only for the last 30 or so years quantum opticians are able to prepare really single-photon states on demand. This is done by creating an entangled photon pair, (e.g., by shooting a laser into a birefrigerent crystal, using parametric downconversion) and then measuring and absorbing one of the entangled photons. Then you are sure to have a true single-photon Fock state ("heralded single-photon preparation").
Another misconception, often found in high-school textbooks, is that the photoelectric effect proves the existence of photons. This goes back to Einstein's famous paper of 1905, which was historically very important to establish the "old quantum mechanics", which finally lead to modern quantum mechanics and after all relativistic quantum field theory and especially QED. Nevertheless it's incorrect, because the photoelectric effect can be explained semiclassically, i.e., by a model where the electric wave is treated as a classical field and only the electrons are described as bound states in the metal. Then the first-order time-dependent perturbation theory, with the electromagnetic wave field as the time-dependent perturbation, leads to the correct formula for the energy bilance of the photoelectric effect, which coincides with Einstein's formula from 1905.
A better experimental argument for the quantization of the electromagnetic field is the Lamb shift or (a bit easier to comprehend) quantum beats:
http://en.wikipedia.org/wiki/Quantum_beats
or better the book cited therein
Marlan Orvil Scully & Muhammad Suhail Zubairy (1997). Quantum optics. Cambridge UK: Cambridge University Press
Whenever you find (semi-)popular descriptions about what a photon might be, be very careful, as most explanations you find (even in textbooks on the university level!) are not up-to-date (to say it friendly) :-(.
Whenever you
Can you elaborate on this? I have always read that the photoelectric effect is the effect that "proves" light is quantized.
You find the calculation I mentioned in Landau, Lifshitz, Vol. 3 and in many other textbooks on quantum mechanics.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
