Relative motion (2 arrow shot up find meeting distance)
Two arrows are shot upwards, one at 40 m/s and the other at 60 m/s, with the second arrow launched 3 seconds later. The meeting height is calculated using the equations of motion, with the first arrow's time represented as t1 and the second as t2. A calculation error was identified regarding the time relationship, with the correct equation being u1(t+3) - 0.5*g*(t+3)^2 = u2*t - 0.5*g*t^2. After simplification, the meeting time was determined to be approximately 3.79275 seconds, but further recalculations indicated a possible error in distance. The final meeting time was found to be 1.5345 seconds at a height of 80.52 meters.
GregR
Two arrows are fired straight up. The first is at 40 m/s and the second at 60 m/s and 3 seconds after arrow one. At what hieght will the arrows meet in the air.
s=ut+1/2 at^2
s1=s2
t2=t1+3
u1(t2+3)+1/2a(t2+3)^2=u2t2+1/2at2^2
Hi GregR, welcome to PF.
Your approach is correct.
But
t2=t1+3 it should be t1=t2+3.
In the equation you have substituted correctly.
Now proceed.
So then:
u1t2+3u1+.5at22+4.5a=u2t2+.5at22
u1=40m/s
u2=60m/s
a=-9.81m/s2
The .5at22 on each side should cancel each other out leaving:
u1t2+3u1+4.5a=u2t2
Solving:
40t2+3(40)+4.5(-9.81)=60t2
40t2+120-44.145=60t2
20t2=75.855
t2=75.855/20
t2=3.79275 seconds
If I use this as the time and recalculate the distance for each arrow it doesn't jive.
Through trial and error I found the meeting time to be 1.5345 seconds at a distance of 80.52 meters from the ground.
Not sure if I'm missing something or its just a minor error on my part.
Your calculation is wrong.
The equation will be
Simplify the equation and solve for t.
Using this formula:
From this I simplified as follows:
u1t +3u1-0.5*9.81*(t2+9) = u2*t - 0.5*9.81*t2
u1t +3u1-4.905*(t2+9) = u2*t - 4.905*t2
u1t +3u1-4.905*t2-4.905*9 = u2*t - 4.905*t2
The -4.905*t2 on both sides should cancel out leaving.
u1t +3u1-44.145= u2*t
Inserting u1=40m/s and
u2=60m/s
40*t + 30*40 - 44.145 = 60*t
40*t + 120 - 44.145 = 60*t
75.855 = 60*t - 40*t
20*t = 75.855
t = 75.855 / 20
t = 3.79275
I wrote it up step by step and got the same results.
Not sure where I'm going wrong here.
Please let me know.
Thanks
(t+3)^2 = t^2 + 6*t + 9
