What Determines Relativistic Momentum: Mass or Velocity?
Relativistic momentum is determined by both mass and velocity, as indicated by the formula momentum = mv/√(1 - v²/c²). The discussion highlights a misunderstanding regarding whether momentum depends solely on mass or includes velocity. The correct interpretation is that both factors are essential in calculating relativistic momentum. The question from the practice exam has been deemed misleading by some participants. Understanding this concept is important for grasping the principles of relativistic physics.
Shark 774
In a practice exam I just did for my upcoming high school mid-year, there was a multiple choice question and the two answers that seemed plausable were "relativistic momentum depends on the mass and velocity of the object" or "relativistic momentum depends only on the mass of the object". I chose the second one with the reasoning that mass and velocity are intertwined and one increases so does the other, so if you know the relativistic mass (and the rest mass) you can easily work out the momentum. I think it's a bit of a stupid question really, but they gave their answer as the first one, not the second one. What do you guys reckon? Just a technicality or is it something worth knowing/worrying about?
Hi Shark 774! :smile:
Momentum is mov/√(1 - v2/c2)
which you can also write as mrelativsiticv …
either way, it depends on both mass and velocity. :redface:
Ok thanks!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
