I Does the momentum of a photon change in a medium with varying speeds of light?
bob012345
For a highly relativistic rocket powered by an external laser such that the thrust is 2*Power/c, the efficiency is dismal at the start when v is low yet approaches 100% as v approaches c. I take efficiency to mean the ability to convert the energy of the beam into usable kinetic energy. Does the momentum kick actually change as the ship gains speed? Is 2P/c just the value when v=0? Conceptually, it's hard to imagine that since most energy is reflected at the start and most energy is converted at the end, that the acceleration is fixed. Yet it is isn't it? Thanks.
Let us first consider a rocket that absorbs the beam. And let's make use of the law of conservation of momentum.
When v=0, the laser device emits momentum at rate power/c, and the rocket absorbs momentum at the same rate.
When v=0.99 c, the laser device emits momentum at rate power/c, and the rocket absorbs momentum at one percent of that rate.
The longer the beam the more momentum it contains, and the beam is getting longer when v is not 0.
When rocket speed is 0.99 c, the momentum of the beam is increasing at rate 0.99*power/c, and the momentum of the rocket is increasing at rate 0.01*power/c.
That is the thrust at any speed, except the P is not the one you think. That P is the one received by the rocket which is a function of v, not the one emitted by the laser which is constant. So the P in your equation decreases with v because of Doppler effect, it is maximum (same as the laser power) at v=0 and goes to 0 as v->c.
Are you assuming that all of the energy of the beam gets converted into kinetic energy of the rocket? (If not, the rocket will heat up and vaporize.)
[Edit: removed the rest of the post as it was based on an incorrect understanding of jartsa's post.]
To analyze the problem, look first at what happens in the instantaneous rest frame of the mirror. The reflected frequency is equal to the incident frequency, more importantly the reflected power is equal to the incident power. Momentum is transferred to the mirror, but no work is done on the mirror, which may or may not be counter-intuitive depending on one's intuition, but applying the formula power = force * velocity makes it clear that if the velocity is zero, the instantaneous rate of transfer of energy to the mirror via the light beam is zero at v=0. This doesn't mean that the light beam isn't exerting a force, rather it means that the rate at which this force does work is zero, because work = force * distance, and power = work/time = force * velocity.
Now re-analyze the same situation in a moving frame by applying the Lorentz transform - or better yet, by Bondi's k-calculus, or some equivalent approach. The incoming frequency is multiplied by k, the outgoing frequency is multiplied by 1/k, where k is the relativistic doppler shift factor ##(1-\beta) / \sqrt{1-\beta^2}##. See for instance https://en.wikipedia.org/wiki/Relativistic_Doppler_effect. The ratio of outgoing frequency to incoming frequency is thus k^2. Power, however, is proportional to the square of the frequency. If this isn't obvious (and it probably isn't), we may need to discuss that point more. Assuming for the moment that this is correct, we can see that the ratio of reflected power to incoming power is proportional to k^4.
Analyzing the problem in the frame of the light source, a frame in which the mirror is moving, the reflected power is still k^4 times the incident power, with k<1. THis implies that the amount of power (energy/time) transferred to the mirror is (1-k^4). So if you have a relativistic doppler shift factor k of 1/2, 1/16 of the power is "wasted" in reflection, meaning that 15/16 of the power is transferred to the mirror.
PeterDonis said:
In the frame of the laser device, the rocket must absorb momentum at the same rate the device emits it; otherwise conservation of momentum is violated.
You should read jartsa's post again. He explained where the missing momentum gets to.
Ah, I see. I've edited my post to remove the incorrect statement.
One alternative is to emit the absorbed energy back, which makes the situation similar to reflection. In the rocket frame we can easily see that that would double the acceleration. Interestingly in the laser device frame the light emitted back has just one percent of the momentum and energy of the light that was absorbed by the rocket, when speed of rocket is 0.99 c.
I think that was my understanding, that if in your example 15/16 th of the power is transferred to the mirror, or ship, then that ends up as kinetic energy.
I don't quite understand what you mean by the momentum of the beam. That is fixed. There should not be an accumulated momentum of the beam at the point of interaction with the ship.
But in the observer frame, the power of the beam remains the same yet my understanding is that most of it gets converted to the kinetic energy of the ship. I thought that extreme red shifting means that most of the energy is converted to motion as seen in the observer frame. One paper described light hitting a ship near c is like light hitting a black hole.
So if I were watching the ship pass by me at .99c and the beam hit it, I think I would see most of that beam energy convert to a change in ship kinetic energy as compared to watching it just start and most energy does not get translated to ship kinetic energy but gets reflected. In my frame then, does the effective momentum transfer change?
Not to end discussion, but thanks to all for the answers so far!
Not sure what observer you mean, but I still think you are confusing the emitted power in the rest frame of the laser with the power received by the rocket. They're not the same thing.
If you actually calculate a numeric example I think you'll find out that most of the energy gets reflected back and only a very small part transferred to KE of the rocket. It would be very red-shifted indeed but you are ignoring the time component, the reflected beam is very low power but over a very long period of time. It integrates to almost the same amount as the incident energy. I am assuming a perfect mirror at the rocket so energy is not lost as heat.
We should be able to account for all things in any frame if we are consistent. I choose the frame where the laser is located, say the Earth frame where the ship starts out. I agree most energy gets reflected at the start. I've seen charts for photon rockets which say the conversion is near 100% as the rocket approaches c. They say the efficiency of the rocket nears 1. What I am trying to clear up is if that means nothing, if the power goes to zero, 100% of zero is zero. Or if it means a lot, the mass grows forever as the speed asymptotically nears c.
The momentum of the beam grows with it's length.
By momentum of the beam I mean the momentum of the beam. :)
In order to not get distracted, let's discuss a "momentum pulse" which is a pulse of momentum emitted by a laser device that emits a pulse of light.
In the laser device frame: The pulse has momentum p. When the rocket absorbs the pulse, the momentum of the rocket increases by p.
In the rocket frame: The pulse has momentum p * relativistic redshift factor. And that's how much the pulse increases the momentum of the rocket, when absorbed.
At speed 0.99 c the relativistic redshift factor is: 0.01 / gamma = 0.01 / 7.1 = 0.0015
(in the rocket frame the laser device is a photon rocket with 99% efficiency, that's where the 0.01 comes from, and then we must also divide the energy by gamma, that's where the 7.1 comes from)
Thanks, so your answer is that if I shine a laser pulse of 10000J at a ship going 0.99c 15J will actually go into changing the kinetic energy of the ship.
I've been thinking a lot about this and currently I think the following. Let's look at energy. The ship is going at v. In my frame the input energy is E and the reflected energy is downshifted by a relativistic red shift which goes as E(1-beta)/(1+beta). The difference goes into the ship and adds to its energy. The ratio of that difference over the input energy is simply R= 2 beta/(1+beta). At v=0, no energy is transferred. At v=1 m/s, R is 6.67E-9. At v=0.1c, R=0.18 and at v=0.99c, R=0.995. In my version, 9950J goes into the ships energy. If gamma is appropriate, and I'm not sure it is since I am looking at the problem from the Earth frame and not the ship frame, then it's still about 1400J. I say that because the pulse is going at c wrt to the ship and it's energy is E just as it hits it. Sure, in the ships frame (or a co-moving frame) it's red shifted but I am not in that frame. I may be wrong but there it is, at least for now. I don't mind being corrected. Thanks.
No that is not my answer. My answer is about the same as your answer.
This is correct, as far as the redshift factor is correct. If anyone doubted this, I would refer to a law called "conservation of energy".:smile:
What was the problem again? According to post #1 changing acceleration is a problem. Well, the acceleration changes, and that is not a problem, that is how I solve this problem. :smile:
Self-powered photon rockets have a more constant acceleration than externally powered photon rockets, isn't that understandable, as there is a changing relative velocity between different parts of the propulsion system in the latter case.
That went wrong. Wikipedia says the redshift is much smaller. So let me try again:
When a source of waves moves away from us at speed 0.99 c, a wavefront moving towards us gains distance to the source at rate: 1.0 c + 0.99 c = 1.99 c. This makes the waves produced by the source 1.99 times longer. I mean longer compared to the situation when the speed of the source is 0.
As the wave source is time dilated by a factor of 7.1, it takes 7.1 times longer time to produce a wave crest than "normally". This makes the waves produced by the source 7.1 times longer than "normally".
The correct way to combine these two effects is to multiply them: 1.99 * 7.1 = 14.13
So the waves are 14.13 times longer than "normally". So the frequency of waves is 1/14.13 of the "normal" frequency.
This result agrees with a formula on the Wikipedia, so this time I made no error, probably. So, what is the efficiency of this wave source, if we decide that it is a photon rocket?
I think I need to revise my answer - I'll do it by means of an example. Suppose we have a gigawatt laser accelerating our object via light pressure, and that in the frame of the laser, it shines for 1000 seconds. Let's assume the object being shined on is moving at 3/5 c, so that the doppler shift factor (which I'll call the k factor) of 2:1.
If an observer on the object measures the power of the pulse, it will go as k^2, i.e. it will be a 250 megawatt pulse. But it will last for 2000 seconds, not 1000 - the same redshift that reduces the frequency doubles the duration of the pulse. So from the point of view of the object, the pulse has a power of 1000/4 = 250 megawatts, but a total energy of 500 gigajoules.
Applying the same symmetrical formula, the power of the reflected pulse will be 1/4 of 250 megwatts, i.e. 62.5 megawatts. But it will be 4000 seconds long so the total energy in the pulse will be 250 gigajoules.
So at 3/5 c, the object will reflect 250 gigajouls of the incoming 1000 gigajoules as measured in the laser frame. So the overall energy effeciency is 75 percent.
Thanks. I made one error in that I forgot a square root for the Doppler formula but as it turns out the ratio I got was correct for the instantaneous efficiency according to Marx [1] and the total efficiency is 1- SQRT[(1-beta)/(1+beta)].
If an observer on the object measures the power of the pulse, it will go as k^2, i.e. it will be a 250 megawatt pulse. But it will last for 2000 seconds, not 1000 - the same redshift that reduces the frequency doubles the duration of the pulse. So from the point of view of the object, the pulse has a power of 1000/4 = 250 megawatts, but a total energy of 500 megajoules.
Applying the same symmetrical formula, the power of the reflected pulse will be 1/4 of 250 megwatts, i.e. 62.5 megawatts. But it will be 4000 seconds long so the total energy in the pulse will be 250 megajoules.
So at 3/5 c, the object will reflect 250 megajouls of the incoming 1000 megajoules as measured in the laser frame. So the overall energy effeciency is 75 percent.
I think you mean 500 gigajoules but I get your point. I agree that for beta of 0.6, the instantaneous efficiency is 75% according to Marx [1].
[1] Marx, G., "Interstellar Vehicle Propelled by Terrestrial Laser Beam," Nature, Vol. 211, July 1966, pp. 22-23.
You're right about the gigajoules, I edited the original post. Thanks for the reference, it's reassuring that it matches.
Thanks all for the answers. I was playing with some numbers and noticed that even though near 100% of the energy of a beam gets converted to rocket kinetic energy, something seems funny. It doesn't give greater acceleration than at the start, all it does is account for the huge delta of energy required in the observer frame to add incremental velocity. I had wondered that perhaps this phenomenon held a clue to the behavior of the controversial EmDrive and Cannea drive devices.
If you have a more specific question than "something seems funny" about the energy requirements" to accelrate an rocket, we might be able to help more. As it is, I'm not sure what the question is.
"Efficiency" is perhaps a confusing criterion to use, considering the efficiency starts out at zero. If you do the analysis in the rockets frame, the beam redshifts, making the power gets weaker by a factor of k^2, and the beam energy for a pulse go down by a factor k with the velocity of the rocket, which we've already discussed. Why would you think a weaker beam with less energy and less power would cause anything but less acceleration?
As far as the EM drive goes, I'd say it goes beyond "controversial". I'd suggest "highly speculative" or "fringe".
Thanks. When I say something seems funny, I don't mean wrong or unphysical but rather surprising. For example, even though the highly relativistic rocket is almost 100% efficient converting most of the beam energy into rocket kinetic energy, the actual numbers were shocking. Adding a gigajoule has almost no effect at beta=0.99 but has a huge effect at low speeds even when the conversion is very inefficient.
Regarding the beam having less energy, in the Earth frame, I accounted for the energy with the redshift. That energy to the ship doesn't just evaporate. If we stick in that frame, the difference must go to the ship. I can see the acceleration and power go down but energy must be conserved.
This brings up a related question. I tried applying the work energy theorem in the relativistic regime. I have no problems with the relativistic kinetic energy difference but the integration force over distance got unwieldy. Then I realized than no books I have seen have relativistic kinematics covered. I don't mean Lorentz transformations, I mean in one frame where the acceleration changes for a fixed force because the mass increases. I couldn't match the integrated work with the change in relativistic energy.
So, the bottom line is that the greater efficiency doesn't seem to mean what I thought.
What I was thinking on the other comment, the thing that won't be named, was just that if one had a relativistic oscillating plasma and one coupled that to beam energy during the phase where the plasma was receding from the beam, one might absorb most of the energy and convert it to plasma kinetic energy. And then to the ship. The plasma might be the electron gas in the walls of a closed microwave container. Naive, yes, and most likely wrong.
A minor but important for communication nit:
wiki said:
Kinematics is the branch of classical mechanics which describes the motion of points (alternatively "particles"), bodies (objects), and systems of bodies without consideration of the masses of those objects nor the forces that may have caused the motion.
So I suspect you're bemoaning the lack of a good introductory textbook treatment of relativistic dynamics, something that treats forces & masses.
Most textbook treatments of relativistic forces that I've seen are fairly advanced, and use 4-vectors. You should be able to find a treatment of relativistic momentum and energy, though.
While it does not include a derivation of the results or explain the dyanamics, there's a good FAQ article with some equations for the relativistic rocket, http://math.ucr.edu/home/baez/physics/Relativity/SR/Rocket/rocket.html, that might be of interest.
An approach I find useful for gaining insight is to take a detour into rapidity. See for instance the wiki article https://en.wikipedia.org/wiki/Rapidity. I'm not sure if there's a good textbook treatment, I seem to recall that Rindler's textbook discussed it some (and it's cited in the wiki article). I think Rindler also treats the accelerated rocket, too, but I can't be certain, I don't have it handy to check. If you can track it down (interlibrary loan, perhaps) it's probably worth looking at, though I can't guarantee it'll answer your question. It's also not necessarily the most modern treatment.
One easy approach is to find the acceleration of the rocket in it's own frame. This is called the proper acceleration. This takes care of all the dynamics issues, once you know the acceleration of the rocket/mirror in its own frame, you can use the principles of kinematics to describe the motion of the rocket in the lab frame (though it may take a bit of work).
Because the rocket isn't moving in its own frame, one can use one's knowledge of Newtonian physics to work out the proper acceleration of the rocket. Once this is known, one can figure out the velocity using the idea of rapidity.
Rapidity, w, is defined as (see the wiki for instance, and I think Rindler's textbook?):
$$w = arctanh \, \beta = arctanh \, v/c$$
where w is the rapidity, v is the velocity, c is the speed of light, and ##\beta = v/c## is convenient (but not necessary), the ratio of v/c.
Because rapidites add, one can write:
$$w = a \tau$$
when the proper acceleration is constant, and when the proper accelration varies with (proper) time, one writes:
$$w(\tau) = \int a(\tau) d\tau$$
One still to find the proper acceleration a. If one consider a pulse of light with some momentum p, and it reflects off a mirror, one knows that the mirror gets a change in momentum of 2p. And it's important to realize that the invariant mass of the mirror (or solar sail + rocket) isn't changed by this process. One does need to know the energy and momentum of the light pulse in the rocket frame, though. So one needs to understand how the doppler shift changes the energy and momentum. One approach to this is to realize that energy and momentum transform via the Lorentz transform, i.e. as a 4-vector. One can possibly work around the need for doing this by figuring out how the frequency ##\nu## transforms and using ##E = h \nu##. One also needs to figure out their arrival rate of the pulses at the rocket/mirror (this is done with the relativistic doppler shift formula). Additionally, one needs to know that for light, E = pc.
I think that should read ##w=\tanh^{-1}\beta=\tanh^{-1} v/c##
Thanks all. I'm digging into these issues. I've picked up Rindler's book and other sources. Started working through some problems. Thanks again!
Ooops - fixed.
MTW's "Gravitation" has a good section on the accelerated observer, but it's couched in terms of tensors, unfortunately.
Thanks, I own that. It's hard to misplace because it's so large it distorts the spacetime around it...
Likes PeterDonis
:biggrin:
I heard that MTW disproves the principle of equivalence - it falls faster than everything else.
Likes PeterDonis
  • #31
Newton's Second Law is relativistically modified as F= gamma^3 ma where m is rest mass. This can be derived from the relativistic form of momentum. A few proper substitutions and integrate over x equals mc^2( gamma2- gamma1). All is well.
  • #32
That form is only if force is colinear with velocity. I assume you know this, but it is a crucial caveat to this formula - which is NOT a general form of relativistic force law.
  • #33
Sounds like you probably don't need this, but for those that do not have the book there is a concise but well paced derivation of the relativistic rocket equations in this link.
Likes vanhees71
  • #34
Thanks, yes. I know the vector form but was primarily interested in co linear motion. Interesting that there is parallel inertia and perpendicular inertia.
  • #35
It's all useful. Thanks.
  • #36
Here’s a question I’ve always wondered. Is it possible to slow light within some gaseous medium and thus increase its momentum? Imagine creating a region around a ship where c=1 m/s and then using a beam where P=E.
  • #37
Try applying conservation of momentum to your question, if the light is increasing its momentum then something else would have to increase its momentum in the opposite direction to keep the total constant. What would that be and how?
  • #38
I know, that would be both the ship and the medium the light is slowed in if light could actually be slowed. The gaseous medium would carry the momentum away that the ship gains as the light passes out of the medium and returns to normal. The question is if light can actually be slowed in a way that increases it's momentum greatly? I've read where light can be slowed to meters per second in certain vapors but don't know about the momentum of such light. I've heard that light actually does have a bigger kick inside glass but don't have a good reference.
  • #39
Imagine creating a region around a ship where c=0.00000001 m/s, or slower if needed, so that we will say that light becomes trapped in the region.
How do light traps behave? For example a mirror lined box with a door which is closed after some light has entered.
  • #40
I don't know about 'light traps'. Please enlighten me. Thanks.
  • #41
Two examples of "light traps":
Trap 1: Vertical light beam enters a box, then the light beam bounces inside the box horizontally. First the light had vertical momentum, then it has no vertical momentum, vertical momentum must be conserved, so the box must now have the vertical momentum that the light had.
Trap 2: An atom absorbs a photon, momentum of the photon becomes momentum of the atom.
Some mathematics:
Energy-momentum relation:
E2=p2c2+m2c4
So massless energy E has momentum: E/c
And energy that has some mass has momentum: Less than E/c
So E/c is the maximum momentum of energy E.
So massless constant energy can not gain more momentum by changing its propagation speed. It can lose momentum by gaining mass and slowing down its propagation speed.
For example: A system consisting of two parallel light beams collides with a lens, which collision causes the beams to become less parallel. After the collision the system has a rest mass that is moving at some speed lower than c, and the system has less momentum than originally, and the lens has absorbed some momentum.
  • #42
Some mathematics:
E2=p2c2+m2c4
Thanks. The question was what happens when c is smaller, like 1 m/s like in a BEC that envelops the ship. Experimental results are hard to come by and theoretical results are contradictory. There has been a over a century of controversy concerning the momentum of a photon in a medium. I just read a paper that claimed to prove the momentum is the same no matter what the speed of light in any medium. Any thoughts here?
P.S. Photon recycling allows one to use the momentum of a photon over and over as long as there is something close to bounce it back. It's been done in the lab with thousands of bounces, moving kg scale objects with typical lab lasers.
