How Do Electric and Magnetic Fields Transform in Different Reference Frames?
  • Thread starter Thread starter physguy420
    E&m Relativity
The discussion revolves around calculating electric and magnetic fields from an electromagnetic potential four-vector in different reference frames. The initial task is to derive the electric and magnetic fields in the lab frame using the given potentials. Subsequently, the focus shifts to transforming these fields to a frame moving at 4c/5 in the x-direction, utilizing Lorentz transformations on the four-potential. Participants emphasize the importance of showing attempts at solving the problems rather than seeking direct answers. The conversation highlights the application of theoretical concepts in practical scenarios.
physguy420
There is an electromagnetic potential four-vector, whose components are (V,Ax,Ay,Az) where V is the electrostatic potential and A is the magnetic vector potential. There is a time-independent electromagnetic field in the lab frame. Its electric and magnetic potentials are:
V=(x^2)y A=(xy-xz, yz-yx, zx-zy)
a) find the electric and magnetic fields in the lab frame.
b) find the electric and magnetic fields in a frame moving at 4c/5 in the x-direction relative to the lab frame. Hint: since the four-potential is a four-vector, you can Lorentz transform it.
Can you do part (a) ?
You need to show that you made an attempt and tell us where you're getting stuck. We're not here to do your homework for you.
