Relativity of simultaneity and doppler effect
cdot
Could someone explain how the relativity of simultaneity and the doppler effect are different?
They have different formulas, different units, and different uses. In fact, I can't think of a reason why there would be any confusion that they are different.
The Doppler effect is something that you actually observe and measure without regard to any theory. The relativity of simultaneity is something that you cannot directly observe nor measure unless you have a theory with which to define it.
Of course, any valid theory must predict the correct Doppler effect, as the theory of Special Relativity does. Special Relativity states that you can select different frames of reference to describe a scenario, and they will each predict the same Doppler effect, even though they can assign different coordinate times to events, which is what the relativity of simultaneity is all about.
As ghwells says, the doppler effect is "raw data", something that relates to what signals you actually get back if you listen to a broadcast and/or bounce a radar or something similar off a moving object.
The relativity of simultaneity is something you can deduce from the doppler effect with a few modest auxiillary assumptions, namely that the doppler effect depends only on the relative velocity, and that the doppler effect doesn't vary with distance, and that there is no preferred direction in space - that it's "isotropic".
Part of the deduction process involves setting up the concept of a "frame of reference" - something that you add-on top of raw sensory data to assign events locations and times to account for signal propagation delays.
If you're interested in the details, you can find them in for example Bondi's "Relativity and common sense". I gather some newer books cover this as well - Mermin was mentioned as one of the authors, but I haven't read his treatment, I assume it's very similar to Bondi's treatment.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
