Reliability of a system (with simple "complex" configuration)
8 replies · 3K views
kalizazzz623
Question: A system consists of 7 equal reliable components having the following configuration with each component has a reliability of 0.9. Find the reliability of the system.
I was taught (and only been taught) with the calculations to obtain reliability of a system with its components arranged in either in series or in parallel. However, I have real trouble in solving these kinds of complex configuration.
For series: Rs = R1R2...Rn
For parallel: Rs = 1-(1-R1)(1-R2)...(1-Rn)
I have search through the internet and realized that this can be solved with the solution used for bridge structure. I tried to mimic the way the solution from the resource (Reliability Engineering: Theory and Practice, by Alessandro Birolini) found (but with only 5 component instead of 7) and come to this:
The first picture showing the reliability of the system with the center component not fail, and the second picture is when the center component has fail. (component number order: 1 to 6, from top left, clockwise; center = 7)
Then, Rs=R7(R1+R6-R1R6)(R2+R5-R2R5)(R3+R4-R3R4) + (1-R7)(R1R2R3+R4R5R6-R1R2R3R4R5R6)
This solution doesn't lead to the answer (0.9575). I tried using Binomial method by considering all sort of possibility but still no help (duh, obviously:frown:), so can anyone enlighten me?
Label the components as
[tex]\begin{array}{ccc} A & B & C \\<br /> &G& \\<br /> D & E & F<br /> \end{array}[/tex]
Imagine we want to send a signal from left to right; the component reliability is the probability that a signal gets through that component. So, to send a signal from left to right, at least one path from left to right must be "open". There are four paths: P_1 =in-ABC-out, P_2 = in-DEF_out, P_3 =in_ABGEF-out and P_4 = in-DEGBC-out. If we let ##E_i## be the event that path ##P_i## is open, can you figure out ##\Pr(E_i)## for each ##i##? For ##i \neq j##, can you see how to get ##\Pr(E_i \cap E_j)##, etc? You need to find
[tex]\text{system reliability} = \Pr \{ \text{at least one of the events }E_1, E_2, E_3, E_4 \text{ occur} \}[/tex]
P(E1)=0.9x0.9x0.9 =0.729
P(E2)=0.9x0.9x0.9 =0.729
P(E3)=0.9x0.9x0.9x0.9x0.9 =0.59049
P(E4)=0.9x0.9x0.9x0.9x0.9 =0.59049
For ##\Pr(E_i \cap E_j)##, thus this means I have to do for ##\Pr(E_1 \cap E_2)##, ##\Pr(E_1 \cap E_3)##, ##\Pr(E_1 \cap E_4)## and the remaining? And by the equation ##\Pr(E_i \cap E_j)##, should I use ##\Pr(E_i \cup E_j)##x##\Pr(E_j)##?
And for the final system reliability, is ##Pr \{ \text{at least one of the events }E_1, E_2, E_3, E_4 \text{ occur} \} = \Pr(E_1 \cup E_2 \cup E_3 \cup E_4)##?
I strongly recommend that you use a symbol ##r## instead of an explicit 0.9, at least until the very last. This is because by using a symbolic constant you can keep separate and keep straight the different effects. So ##\Pr(E_1) = \Pr(E_2) = r^3##, ##\Pr(E_3) = \Pr(E_4) = r^5##, etc.
The general inclusion-exclusion says that
[tex] \text{answer} = R = \Pr \{ E_1 \cup E_2 \cup E_3 \cup E_4 \} = S_1 - S_2 + S_3 - S_4, \\<br /> \text{where}\\<br /> S_1 = \sum_i \Pr(E_i)\\<br /> S_2 = \sum_{i < j} \Pr(E_i E_j) \\<br /> S_3 = \sum_{i < j < k} \Pr(E_i E_j E_k)\\<br /> S_4 = P(E_1 E_2 E_3 E_4)[/tex]
Here I have used the simpler notation ##AB## or ##ABC## instead of ##A \cap B## or ##A \cap B \cap C##, etc.
For ##E_1 E_2## all components except G must work; for ##E_1 E_3## all components except D must work. Look at all the other ##E_i E_j, i < j,## in the same way, and do the same for ##E_i E_j E_k, i < j < k## as well as for ##E_1 E_2 E_3 E_4##. In this way you can obtain ##S_1, S_2, S_3, S_4## in terms of ##r##. And yes, it is a bit messy and lengthy, but welcome to the world of reliability computation.
I strongly recommend that you use a symbol ##r## instead of an explicit 0.9, at least until the very last. This is because by using a symbolic constant you can keep separate and keep straight the different effects. (Besides which, this allows you to vary ##r## and see how the answer changes, because rarely would you know an exact value of ##r## accurate to infinitely many decimal places.)
Sorry for being bad at elementary probability, but does ##E_1 E_2## equals to ##r^6##? And for ##E_1 E_2 E_3##, is it equals to ##r^7##? Thanks in advance.
You tell me.
Ray Vickson said:
You tell me.
Well I'm not really sure if I'm doing it wrong or correctly, cause it doesn't yield the answer.
My solution:
[tex] S_1 = \sum_i \Pr(E_i) \ = 2r^3+2r^5\\<br /> S_2 = \sum_{i < j} \Pr(E_i E_j) \ = 5r^6+r^7\\<br /> S_3 = \sum_{i < j < k} \Pr(E_i E_j E_k)\ =4r^7\\<br /> S_4 = P(E_1 E_2 E_3 E_4) =r^7\\[/tex]
then
[tex] Pr \{ E_1 \cup E_2 \cup E_3 \cup E_4 \} = 2r^3+2r^5+2r^7-5r^6 = 0.9383 (≠0.9575)[/tex]
It seems some how my approach is wrong, but I can't think of other ways.
My solution:
then
Your answer is correct (although I would round it off to 0.9384). The 0.9575 figure is wrong. In fact, using your (correct) expression for ##R(r)## you can solve the equation ##R(r) = 0.9575## numerically, to get ##r = 0.91797978##.
