Resistance and current question
The discussion revolves around calculating the current passing through a person's body and an alternative path to ground given specific resistances and voltage. For a body resistance of 900 ohms connected to 110V, the current through the body is calculated to be approximately 0.122A. When considering a parallel path to ground with 40 ohms resistance, the total current is found to be 2.87A, with 2.75A passing through the ground and 0.122A through the body. The challenge arises in determining the current through the person when the voltage source limits the maximum current to 1.5A, leading to a debate on the correct application of Ohm's Law and current division principles. Ultimately, the discussion emphasizes the importance of understanding current dividers in parallel circuits to accurately solve the problem.
Gardalay
Suppose that a person's body resistance is 900ohms.
a) what current passes through the body when the person accidentally is connected to 110V?
b) if there is an alternative path to ground whose resistance is 40 ohms, what current passes through the person?
c) if the voltage source can produce at most 1.5A, how much current passes through the person in case b)?
V=IR
A) V=IR, I=0.122
B)1/900+1/40=0.026^-1=38.29 ohms, 110/38.29=2.87amps, 0.122a passes through the person, 2.75amps passes through the ground
C) Would the answer just be 1.372amps since 2.75-1.5=1.25 and then 1.25+0.122=1.372?
V=IR
A) V=IR, I=0.122
I would solve part C differently. 1.25 amps is only a little bit more than 10X as much current as 0.122 amps, yet one resistor has over 20X the resistance compared to the other. So the difference in current between the body and the other path must be greater than what you have and still equal to a total of 1.5 amps when added toegther.
I found out the answer was to be 1.5*40/940.
I have no idea how the person got 40/940 can someone please explain
It's just from Ohm's Law. Have you learned about voltage dividers yet? How about current dividers? The problem presents you with a current divider. If you have the same voltage across two parallel resistors, how does the current divide between the two paths? How would you calculate it?
Wouldn't I just add 1/40+1/900=38.29ohms?
Not if you want to figure out how the current divides between the two branches, which I think is part of this question.
If you have 1 Ohm in parallel with 2 Ohms, how does the current divide between the two branches? In what ratio?
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
