Resistance of parallel resistors
The discussion focuses on calculating the equivalent resistance of parallel resistors with values of 5 ohm, 20 ohm, 40 ohm, and 50 ohm. The formula for finding the equivalent resistance is provided as 1/Rx = 1/R1 + 1/R2 + 1/R3 + 1/R4. Participants suggest using the expression to compute the total resistance. The calculation involves finding the reciprocal of the sum of the reciprocals of each resistor's resistance. The equivalent resistance for the given values is determined through this method.
athenaroa
If resistors of 5 ohm, 20 ohm, 40 ohm, and 50 ohms are parallel with each other, the equivalent resistance would most nearly be how many ohms?
Have you no expression for the resistance of parallel resistors?
Well, do you have options? Sounds like a multiple choice question. Nearly how many ohms?
try 1/Rx = 1/R1 + 1/R2 + 1/R3 +1/Retc... !
1/((1/5)+(1/20)+(1/40)+(1/50))
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
