Solving Resolution Problem Homework Statement
  • Thread starter Thread starter Ownaginatious
    Resolution
The discussion revolves around solving a homework problem related to the resolution of an American standard television picture, specifically focusing on the Rayleigh criterion. The key parameters include the diameter of the pupils (5.13 mm) and the average wavelength of light (570 nm). The main equation used is θ = 1.22 * (wavelength)/(diameter), which helps determine the minimum viewing distance relative to the vertical dimension of the picture. Participants clarify that the vertical dimension can be derived from the total number of horizontal lines (485) on the screen. Ultimately, the solution involves understanding the relationship between the viewing distance and the ability to resolve the lines, leading to a correct answer through the application of the derived formulas.
Ownaginatious
I'm not sure what I'm messing up here:
"An American standard television picture is composed of about 485 horizontal lines of varying light intensity. Assume that your ability to resolve the lines is limited only by the Rayleigh criterion and that the pupils of your eyes are 5.13 mm in diameter. Calculate the ratio of minimum viewing distance to the vertical dimension of the picture such that you will not be able to resolve the lines. Assume that the average wavelength of the light coming from the screen is 570 nm."
diameter of pupils = d = 5.13*10^-3 m
wavelength = r = 570 * 10^-9 m
Now I think I'm supposed to use this equation:
(theta) = 1.22 * (wavelength)/(Diameter)
I'm not really sure where to go from here, and can't figure out how the 485 horizontal lines plays into this. Can someone guide me through this one? I've never had a problem in my homework like this before.
Thanks!
- Dillon
Vertical dimension of the picture tube / numbers of lines = the distance between two lines which is to be resolved.
But there is no vertical dimension of the screen :s
The answer may be in the form of d/D
But what would the upper-case D represent?
Vertical dimension of the picture tube.
I'm still unsure of how to solve the problem...
In this problem theta = (D/485)/d = 1.22(wavelength/diameter)
Okay, great, that yields a correct answer :)
If you don't mind rl.bhat, could you show me how you derived that (D/485)/d?
EDIT:
Oh wait, never mind, I just realized that you just used s = (radius)*(theta). Thanks again!
