Resolving vectors into a unit vector
The discussion focuses on resolving vectors into a unit vector, specifically in the context of electric field polarization for an antenna. The unit vector along the antenna polarization is derived using the formula u_a = 1/Sqrt(2) (a_x + a_y), where 1/Sqrt(2) normalizes the vector's length to one. This normalization factor is calculated based on the magnitude of the vector formed by a_x and a_y. If a factor of 2 is added to a_y, it would alter the resultant unit vector, necessitating a recalculation of the normalization factor. Understanding these principles is essential for accurately defining unit vectors in vector addition contexts.
jmc
electric field polarization for a given antenna is expressed as:
E_i = (a_x + a_y) E (r, theta, phi)
The unit vector along the antenna polarization is found as u_a = 1/Sqrt(2) (a_x + a_y)2. Question
Where/how is the 1/Sqrt(2) found to resolve those other 2 vectors into a unit vector? Is there a formula or is it some kind of vector addition?
What if there was a factor of 2 added to a_y in the original equation - how would it change that unit vector result?
Thank you
A unit vector is defined to have length one. Given any vector ##\vec v## it can be multiplied with ##N = \frac{1}{\sqrt{\vec v^2}}## to give a vector ##\frac{\vec v}{\sqrt{\vec v^2}}## which is of unit length.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
