What Factors Affect the Natural Frequency of a Wineglass?
  • Thread starter Thread starter 06mangro
    Resonance
The natural frequency of a wineglass is primarily influenced by its density, shape, and thickness. Length plays a crucial role, as it determines the standing wave patterns and the number of nodes that can form. The formula f = nv/4L illustrates this relationship, where n represents the harmonic number, L is the length, and v is the wave velocity. As objects increase in size or complexity, the factors affecting their natural frequency become more intricate, especially with multiple materials involved. Understanding these principles is essential for analyzing the vibrational characteristics of various objects.
06mangro
Hello,
I was just wondering what the natural frequency (of a wineglass) depends on,
i would say density of the glass, the shape, thickness,
could anyone tell me about in more detail?
Does this apply for any object (as the object gets bigger it becomes more complicated and especially if it has more than one material making it up?)
06mangro said:
Hello,
The length will affect it more than anything; the standing wave that occupies it is determined in large by the length, as this affects the number of nodes that can form..
f=\frac{nv}{4L}
n = harmonic [where you can only have odd harmonics [1, 3, 5, etc].]
L = length.
v = velocity of the wave.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
