Resonant behaviour of damped beam
The quality factor (Q) of a cantilever beam vibrating in air is determined by the damping factor (ζ), with the relationship Q = 1/(2ζ) for small damping values (ζ ≤ 0.1). To calculate Q, one must first define the loading conditions, including the self-mass of the beam. The equivalent viscous damping is influenced by the surrounding fluid medium, which is crucial for accurate calculations. The expressions for Q are applicable to both micro and nano cantilevers, though specific considerations may be necessary for these smaller scales. Understanding these principles is essential for analyzing the resonant behavior of damped beams.
laxman.kosuru
hi all
i have a problem in finding the quality factor of cantilever beam (one end is fixed and other end is free ) vibrating in air /other medium? how the qualtiy factor expression for beam is calculated? whether all these expressions applicable to micro and nano cantilevers.
please explain me.
i am new to this area. i read books on vibrations of beam. i didnt get anything
please mention steps for finding quality factor of cantilever beam in air medium(damped system)
Thanks
Your first step is to define the loading, including self mass.
laxman.kosuru said:
hi all
please explain me.
Thanks
The quality factor Q is a measure of the sharpness of a peak of resonance and also the damping.
For small values of the damping factor \zeta, that is, \zeta \leq 0.1,
<br /> Q = \frac{1}{2 \zeta}<br />
For mechanical systems, it is useful to get a measure of the equivalent viscous damping. In your case, it might be related to the fluid around the beam.
A good reference is:
F. S. Tse, I. E. Morse and R. T. Hinkle. Mechanical Vibrations - Theory and Applications.
Thanks jolile
could you please give me the expression for cantilever q factor in air medium
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
