Resonant Frequencies of Coaxial Cylinders
The discussion focuses on determining the resonant frequencies of two coaxial cylinders, emphasizing that the resonant frequency is influenced by the length of the cylinders and their configuration. The resonant wavelength differs for closed and open-ended cylinders, with the cavity between them requiring specific formulas. Key factors include the type of connector used, the impedance of the connecting cable, and whether the ends of the assembly are open or shorted. The impedance of the coaxial assembly can be calculated using a specific formula, and the lowest resonant frequency is identified as the 1/4 wave frequency. Overall, understanding the impedance and configuration is crucial for accurately determining the resonant frequencies in coaxial cylinders.
DRossman2
Does anyone know of a formula for determining the various resonant frequencies of 2 coaxial cylinders with radius a and b and height h? Thanks.
well the resonant frequency is basically determined by the length of the tube (cyclinder). In closed end cyclinders the resonant frequency has a wave length of four times the length of the cylinder. In order to get it resonating required a wave of enough amplitude (energy) to make it resonate.
Similarly the resonant wave length in an open ended cylinder is double the length of the cyclinder
I appreciate that, but my question pertains to two cylinders, on inside the other. I need to find the resonant frequency of the cavity between them. I have the formula for a single cylinder, but can not find one for the coaxial set.
First, I assume you have a connector on one end. What kind of connector, and what is the impedance of the connecting cable? 50 ohms? 75 ohms
Second, is the other end of the coaxial tube assembly open or shorted?
third, the impedance of the coaxial tube assembly is
Z = [377/(2 pi)] Ln(b/a) where b is the radius of the larger cylinder.
Fourth, the one-way transit time is h/c where c= 3 x 108 meters per sec. h is the full wave wavelength. The full wave frequency is c/h. The lowest resonant frequency is the 1/4 wave frequency, c/4h. If one end is open, the other looks like a short. If one end is shorted, the other end should have an impedance Z2/(short resistance). A quarter wave line is an impedance transformer. If the Z of the coaxial tube is not the same as the impedance of the cable, then you have an impedance mismatch. See attached thumbnail for a 0 to 100 MHz frequency sweep of a 10-ns long coaxial 50 ohm line. The 10-ns line looks open at the 1/4 and 3/4 wavelength frequencies (25 and 75 MHz), and shorted at the 1/2 and 1/1 (50 and 100 MHz) wavelength frequencies
[Edit] Here is a website for quarter wave lines referred by Berkman
http://www.microwaves101.com/encyclopedia/quarterwave.cfm
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
