Response of a system (Control theory)
The discussion focuses on understanding the response of a control system, particularly regarding oscillations characterized by a transfer function. The user is studying for an exam and seeks clarification on calculating maximum elongation when the final value is zero. The formula provided for maximum elongation involves the damped coefficient, but it becomes problematic when the final value is zero. Participants are encouraged to provide insights or solutions to this specific scenario. The conversation highlights the complexities of control theory in relation to system responses.
Domenico94
Hi everyone. I'm studying for the exam of control theory, and now I'm having an hard time with the response of a system, in particular when we have oscillations.
Suppose you have a system, with a transfer function, say, G(S), in the form:
G(S) = 1
(s ^2 + 2a*w (s) + w^2)
Then, if we have oscillations, we can calculate the maximum elongation (in percentage), over final value, with the formula
S = (final value)* 100 * e ^ ((-pi * a)/sqrt(1 - a^2)),
in which a is the damped coefficient.
The problem is, if the final value is 0, what should I do there? Thank you for your help
Anyone?
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
