Calculating the Force on a Parachuter Falling at 25 ms-1
  • Thread starter Thread starter songoku
    Falling Force
The discussion centers on calculating the resultant force acting on a parachuter with a mass of 75 kg falling at a constant speed of 25 m/s. The relevant equation used is F = ma, where 'm' is mass and 'a' is acceleration. Since the parachuter is falling at a constant speed, the net force is zero, leading to the conclusion that the correct answer is (d) No net force. Participants confirm this understanding, reinforcing the concept that constant velocity indicates balanced forces. The discussion effectively clarifies the relationship between speed, mass, and resultant force in this scenario.
songoku
A parachuter of mass 75 kg falls towards the Earth at a speed of 25 ms-1. What is the resultant force acting on the person?
a. 750 N
b. 450 N
c. 1,350 N
d. No net force
e. 1,500 N
F = ma
I think the answer is (d) because 25 ms-1 is constant speed. Am I right?
Thanks
Yes. You are right.
Thanks a lot Mr. rl.bhat :smile:
