Resultant of thirty vectors of a polygon
To determine the resultant of thirty vectors, each with a magnitude of 2N, represented by the sides of a regular polygon, the interior angle is calculated to be 168°. The components along the X and Y axes are derived using trigonometric functions based on this angle. The resultant is found by summing these components and applying the equation R² = Rx² + Ry². A participant expresses concern about the lengthy process and seeks a simpler method for solving such problems. The discussion also touches on the concept that if vectors are arranged head-to-tail in a closed polygon, their sum equals zero.
sadaf2605
University Physics(12th ed) said:
Thirty vectors, each of magnitude 2N, are represented by the sides of a regular polygon taken in order. Determine their resultants.
equation, square of resultant, R2 = Rx2 + Ry2
interior angle of a polygon = (n-2)* 180°/n
= (30 - 2)* 180°/30
= 168°
components on X axis:
Ax1 = 20* cos 168°
Ax2 = 20* cos (168°+168°)
Ax30 = 20* cos (168° * 30)
Rx = Ax1 + Ax2 + . . . +Ax30
components on Y axis:
Ay1 = 20* sin 168°
Ay2 = 20* sin (168°+168°)
Ay30 = 20* sin (168° * 30)
Ry = Ay1 + Ay2 + . . . +Ay30
thn,
R2 = Rx2 + Ry2
i think we can solve this kind of problem this way, but this process is so lengthy so i am expecting some alternative easy and short way to solve such problems, anyone to help?
I'm not sure I understand the problem.
If you add any number of vectors head-to-tail, and the head of the last one meets the tail of the first one, then the sum is always zero.
Thanks alot!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
