Understanding Reversible Processes: Definition, Examples, and Importance
  • Thread starter phymatter
  • Tags
    Process
In summary, a reversible process is one in which the system and its surroundings can be restored to their initial states by reversing the direction of the process. This process must also be quasi-static, meaning it occurs through infinitely small steps and the system is always in equilibrium. However, in real life, achieving 100% accuracy in a reversible process is impossible due to the need for infinitely small steps and detailed observations.
phymatter
131
A process is said to be reversible if the system and its surroundings are restored to their respective initial states by reversing the direction of the process. A reversible process has to be quasi-static
This is what my book says , but consider this :
i take something in an adiabatic container with a piston and pull up the piston to change its height by [tex]\Delta[/tex]h in 1 step, then again I bring it back to same height in 1 step , now this process is not quasi-static but it has been reversed !
also it is back in the same state!
also why should the system be always in equilibrium to be reversable
The process will have to be accurate by 100%, that means the amount of work done on the system should be identical to the smallest amount of work done by the system...if you're measuring this, it's only achievable if you're observing the system by infinitely small steps, or making progress through infinitely small steps and each step is observed.
A smooth graph formed off the adiabatic process will mean that you have every infinity small detail proving that the area of the graph formed when work is done on the system = the area of the graph formed when work is done by the system...this is impossible in real life.
I would like to clarify and expand upon the concept of reversible processes. While the definition mentioned in the content is accurate, it is important to understand that there are certain conditions that need to be met for a process to be truly reversible.
Firstly, as mentioned, a reversible process needs to be quasi-static, meaning that it needs to occur at an infinitesimally slow rate, allowing the system to continuously adjust to the changes happening. This is crucial because any sudden or abrupt changes can lead to irreversibility in the process.
In the example mentioned, where the piston is pulled up and then brought back down in one step, it may appear to be a reversible process as the system returns to its initial state. However, this process is not quasi-static and therefore not truly reversible. The sudden change in the height of the piston would not allow the system to adjust to the changes and may result in an increase in entropy, making the process irreversible.
Additionally, a reversible process requires the system to be in thermodynamic equilibrium throughout the entire process. This means that the system needs to be in a state of constant temperature, pressure, and composition. Any deviation from equilibrium can result in irreversible changes in the system.
In conclusion, while the concept of reversible processes may seem simple, it is important to understand the conditions that need to be met for a process to be truly reversible. Quasi-staticity and thermodynamic equilibrium are essential for a process to be reversible, and any deviation from these conditions can lead to irreversibility.
What is a reversible process?
A reversible process is a type of thermodynamic process where the system undergoes a series of changes that can be reversed by an infinitesimal change in the system's parameters, without causing any significant changes in the environment.
What are some examples of reversible processes?
Some examples of reversible processes include the expansion and compression of ideal gases, melting and freezing of solids, and the reversible chemical reaction between hydrogen and oxygen to form water.
Why are reversible processes important?
Reversible processes are important because they allow us to study the fundamental principles of thermodynamics, such as heat transfer, work, and energy, in a controlled and predictable manner. They also serve as the theoretical basis for the development of efficient and sustainable energy systems.
Can all processes be reversed?
No, not all processes can be reversed. Reversible processes are idealized models and are only possible in systems that are in thermodynamic equilibrium. In reality, most processes are irreversible and result in a net increase in entropy.
How are reversible processes different from irreversible processes?
The main difference between reversible and irreversible processes is the ability to reverse the process without any change in the environment. Reversible processes are also highly efficient, while irreversible processes result in energy loss due to irreversibilities. In addition, reversible processes follow a reversible path on a thermodynamic diagram, while irreversible processes do not.
  • Classical Physics
  • Classical Physics
  • Classical Physics
