Ridiculous manipulation question
  • Thread starter Thread starter operationsres
    Manipulation
operationsres
ECONOMETRICS CALCULUS.
1. The PRECEDING question and solution
Differentiate
with respect to b1
My solution:
df(b0,b1)/db1 = 2Σ[(yi-b0-b1xi)*(-xi)]
2. the ACTUAL question
By setting d,f(b0,b1)/d,b1 = 0, show that you obtain
(Hint: you will have to substitute b0 = yBAR - b1(xBAR), and use the results from the previous question.)
3. Some properties that we can assume while answering the question.
4. The attempt at a solution (I can't do it)
Letting 2Σ[(yi-b0-b1xi)*(-xi)] = 0
0= Σ[(yi-b0-b1xi)*(-xi)]
0= Σ(-yi xi)+Σb0xi+ Σb1xi ^2
0= -Σ (yi xi)+b0 Σxi+b1Σxi^2
b1Σxi^2=Σyi Σxi – (yBAR-b1xBAR)Σxi ... (Re-arranging and substituting for b0)
b1Σxi=Σyi -yBAR+b1xBAR ...... (dividing both sides by Σxi)
b1Σxi – b1xb = Σyi – yBAR
b1(Σxi – xb)=Σyi – yBAR
b1= (Σyi – yb)/(Σxi – xBAR)
= (Σyi – Σyi /n)(Σxi – Σxi/n)
Differentiate
with respect to b1
My solution:
The line above should be an equation. It should NOT start with =. The equation you're starting with says that
\frac{\partial f}{\partial b_1} = 0
Each line after the first one should be an equation. Ultimately you should get an equation that starts with b1.
That's just me being unformal though.
2=x
=y
is just 2=x=y.
I will formalise it when I figure out the answer.
Do you know where my actually working went wrong?
2=x
=y
is just 2=x=y.
If 2 = x, and x = y, then you can say 2 = y or 2 = x = y. This is different from what I'm talking about, and it's not just a matter of being informal vs. being formal. It's the difference between solving an equation and simplifying an expression, which are two entirely different operations.
Start with 2Σ[(yi - b0 - b1xi)*(-xi)] = 0
and solve for b1, using the properties of summations.
Each step should be an equation!
Hi operationres, it may seem that Mark is being nit-picky, but his comments are good advice. Even though you aren't handing in your forum post for marks, it is still in your best interests to make your workings as clear as possible. Doing so makes it easier for us to see where you are going wrong, and also gives you practice in writing things in a logical, mathematically correct manner (practice at this helps make things go quicker on your exams :wink: ).
Here it looks like you are claiming that
\sum_{i=1}^nx_iy_i=\left(\sum_{i=1}^nx_i\right)\left(\sum_{i=1}^ny_i\right)
Try plugging in some actual numbers to convince yourself that this is not correct.
You also seem to think that
\frac{\sum_{i=1}^n(x_i)^2}{\sum_{i=1}^nx_i}=\sum_{i=1}^nx_i
Which again isn't true (plug in some actual numbers to convince yourself of this).
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
