Rigid Body Equilibrium problem (no calculus)
The discussion revolves around solving a rigid body equilibrium problem involving a gymnast on a beam supported by two posts. To find the forces exerted by each support, participants suggest using the principle of moments, which requires taking moments about each support to exclude the force from consideration. Clarifications are sought regarding the lever arm and whether the torque calculation involves only the gymnast's weight or both the gymnast and the beam. Participants emphasize the need for two equations to solve for the two unknown forces. The conversation highlights the importance of understanding torque and equilibrium in analyzing the forces acting on the beam.
minhaitran
Consider a gymnast on a bean placed on upright posts. The beam has a mass of 10kg and the gymnast has a mass of 50kg. The beam is 5 meters long, and the gymnast is 1 meter from the right side. The gymnast may be treated as a particle.
Find the force exerted by each support on the beam. There are two unknowns in the problem, and thus we need two equations.
Principle of moments. Take moments about each support - the force exerted by that particular support would thus be excluded from consideration.
So how will that help me find the force on that support?
You can either:
1) Take moments about each support (which will yield the normal force on the other support) or
2) Take moment about one support to get the answer for the other support, and then use translational equilibrium criteria to obtain the force on the first support
I have a very similar problem.
In this case, what is the lever arm? I know torque = lever arm x force. Is the force the gymnast, or both the gymnast and the beam? Is the beam the lever arm?
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
