MHB Ring Homomorphisms from Z to Z .... Lovett, Ex. 1, Section 5.4 .... ....
Math Amateur
MHB
I am reading Stephen Lovett's book, "Abstract Algebra: Structures and Applications" and am currently focused on Section 5.4 Ring Homomorphisms ...
I need some help with Exercise 1 of Section 5.4 ... ... ...
Exercise 1 reads as follows:View attachment 6452Relevant Definitions
A ring homomorphism is defined by Lovett as follows:https://www.physicsforums.com/attachments/6453Thoughts so far ... ...
One ring homomorphism, $$f_1 \ : \ \mathbb{Z} \rightarrow \mathbb{Z}$$ would be the Zero Homomorphism defined by $$f_1(r) = 0 \ \forall r \in \mathbb{Z}$$ ...
($$f_1$$ is clearly a homomorphism ... )
Another ring homomorphism $$f_2 \ : \ \mathbb{Z} \rightarrow \mathbb{Z}$$ would be the Identity Homomorphism defined by $$f_2(r) = r \ \forall r \in \mathbb{Z}$$ ...
($$f_2$$ is clearly a homomorphism ... )
Now presumably ... ... ? ... ... $$f_1$$ and $$f_2$$ are the only ring homomorphisms from $$\mathbb{Z} \rightarrow \mathbb{Z}$$ ... ... but how do we formally and rigorously show that there are no further homomorphisms ... ...
Hope that someone can help ...
Peter
Have no tried the following idea ... but no luck ...Suppose $$\exists \ f_3 \ : \ \mathbb{Z} \rightarrow \mathbb{Z}$$ ... ... try to show no such $$f_3$$ exists ... at least no $$f_3$$ that is different from $$f_1 , f_2$$ exists ... ...Let $$f_3(2) = x $$ where $$x \in \mathbb{Z}$$ ...Then $$f_3(4) = f_3( 2 \cdot 2 ) = f_3( 2) f_3( 2) = x^2 $$
and
$$f_3(4) = f_3( 2 + 2) = f_3( 2) + f_3( 2) = x + x = 2x$$
Then we must have $$x^2 = 2x$$ ... ... ... (1)
I was hoping that there would be no integer solution to (1) ... but $$x = 0$$ satisfies ... so ... problems ..
Maybe a similar approach with different numbers will work ... ...
Can anyone comment on this type of approach ...
Peter
Here's an outline of how I would do it.
First, $f(n+1) = f(n) + f(1)$. Use this to prove by induction that $f(n) = nf(1)$ for all positive $n$.
Next, $-n + n = 0$, so $f(-n) + f(n) = f(0) = 0$. Therefore $f(-n) = -f(n) = -nf(1)$. Thus $f(n) = nf(1)$ for all $n$, positive or negative.
Finally, $1^2 = 1$, so $\bigl(f(1)\bigr)^2 = f(1)$. It follows that $f(1)$ must be either $0$ or $1$. So $f(n)$ must be either $n\cdot0 = 0$ or $n\cdot1 = n$.
Thanks Opalg ...
Have the idea now ... very grateful for your help!
Peter
