Calculating Inductance in an RL Circuit
To calculate the inductance in the RL circuit, the relevant equations include the time constant τ = L/R and the current equation I(t) = (EMF/R)(1 - e^(-tR/L)). Given a 9.0 V battery, a 5.5 ohm resistor, and a current increase from 0 to 0.30 A in 0.17 seconds, the inductance can be determined by substituting known values into the equations. The attempt to find L yielded an incorrect value of 5.1, indicating a need for careful application of the equations. The discussion emphasizes the importance of correctly solving for the unknown inductance to progress to the next part of the problem.
n.hirsch1
An RL circuit has a 9.0 V battery and a 5.5 ohm resistor. When the switch is closed, the current in the circuit is observed to increase from 0 to 0.30 A in 0.17 s.
A) What is the inductance?
B) How long after the switch is closed does the current have the value 0.47 A?
τ = L/R
EMF = L*I / t
I = EMF / R *(1-e^-tR/L)
I don't know how to find a time constant, my text doesn't explain it, which makes me think that this question may not even use this equation. I can't get to part B without an answer to part A. By using the second equation I got L = 5.1, but that isn't correct.
τ = L/R
EMF = L*I / t
are you sure you don't know how?
No, I don't. Its asking for inductance, I have resistance, I have no idea how to get the time constant.
I(t) = \frac{v}{R} e^{\frac{-tR}{L}}
You know the value of current = 300mA at t = .17. v = 9 and r = 5.5. This leaves 1 unknown. Solve for it.
