How to Calculate the Flight Time and Apex for a Model Rocket Launch in Excel?
  • Thread starter Thread starter radarspec
    Launch Rocket
The discussion focuses on calculating the flight time and apex of a model rocket using Excel, with an emphasis on understanding the three stages of its flight. The first stage involves a launch with a force of 16N, resulting in an acceleration of 310.19 m/s² and reaching a height of 10.47 meters after 0.15 seconds. In the second stage, the rocket coasts upward under the influence of gravity, but there is confusion regarding the calculations, particularly the velocity at the end of this stage, which should decrease due to the downward force of gravity. The apex is suggested to be the sum of the heights from both the first and second stages, totaling 121.58 meters. Clarifications are sought on the correct application of gravitational force and the overall calculations for total flight time and apex.
radarspec
A brief explanation, this assignment is to be done in Excel and also has to be turned in with handwritten solutions for finding total flight time and apex. If I can get the handwritten part done Excel is a piece of cake.
A model rocket is launched and I am to evaluate the 3 stages it goes through. During the first 0.15s the rocket (m=0.05 kg) is launched with a force of 16N. It then coasts upward while being slowed done by gravity (g=9.81m/s2. After it reaches apex(max altitude it starts to fall back down. It also deploys a parachute 6 sec. after the motor stops with a constant speed of 10 m/s until it hits ground. Calculate the speed and altitude of the rocket over it's flight time and plot them.
Knowns:
g=9.81m/s2
FE=16N
m=0.05 kg
vo=0m/s
\Deltat=0.01s
Unknowns:
acceleration
velocity
height
total time
\SigmaF=ma
v(t)=vo+at
h(t)=ho+vo+.5at2
Stage 1: 0\leq t \leq 0.15s
use dt=0.01s (was told to do this by teacher for stage 1)
\SigmaF=ma
Fe-w=may
ay=\frac{Fe-w}{m}
ay=\frac{16N-(0.05)(9.81)}{0.05}=310.19m/s2
v=vo+at
v=0+(310.19)(0.15)=46.53m/s
h=ho+v0+.5at2
h=.5at2
h=.5(310.19)(0.15)2
h=10.47 m
Stage 2: 0.15 \leq t \leq 6.15s
\SigmaF=ma
-w=may
ay=-g
v=vo+at
v=46.53+(9.81)(6.15)=106.86m/s
h=10.47m+(46.53)(6.15)+.5(-9.81)(6.15)2=111.11m
Stage 3: 6.15 \leq t \leq total time
Stage 3 is were I get lost could some point me in the right direction as to find total time and apex.
Your stage 2 is incorrect. At the end of stage 1, you have the rocket's velocity as 46.53 m/s upwards (correct). Then at the end of stage 2, during which the only force is gravity (downward), you have the rocket's velocity as 106.86 m/s upwards. Ask yourself, does this make any sense?
So I would be using -9.81 instead of 9.81 for gravity now? Also would apex be the addition of the height of stage 1 & 2 added together. 111.11 + 10.47 = 121.58m?
Also the velocity and height numbers seem small given the acceleration at lift off.
