How Fast is the Roller Coaster Car at the Top of the Hill?
To determine the speed of a roller coaster car at the top of a 10 m radius hill where its apparent weight is half its true weight, the relevant equations are A = v^2/r and F = ma. The apparent weight being half indicates that the net force acting on the car is equal to its weight minus the centripetal force required to keep it moving in a circle. The weight cancels out in the calculations, simplifying the problem. The discussion emphasizes the importance of correctly applying these principles to solve for the car's velocity. Understanding the relationship between apparent weight and centripetal force is crucial for finding the solution.
hbteen
As a roller coaster car crosses on the top of a 10 m radius hill (the track is underneath the car), its apparent weight is one-half its true weight. What is the car's speed at the top?
A=v^2/r
F=ma
I tried saying the weight was .5 and solving for velocity, but I still have a missing # for the Force variable.
Where do I go from there?
Welcome to PF!
Hi hbteen! Welcome to PF! :smile:
A=v^2/r
F=ma
The weight doesn't matter … it cancels out. :wink:
Show us what you tried, and then we'll see where the problem is. :smile:
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
