Why Does a Penny Appear to Float When Dropped on a Roller Coaster Descent?
voutetesbelle
Why would a penny seem to "float" above you if you dropped it as you were descending a roller coaster?
Hint: Climb a tree and jump off while at the same time dropping a penny. What does the penny do relative to you?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
