Rolling as Translation and Rotation Combined
An automobile traveling at 30.0 km/h has tires with an 85.0 cm diameter and comes to a stop uniformly in 15 complete turns. The angular speed was calculated to be 19.6 rad/s. The formula used for angular acceleration is correct, and the calculated value of 2.038 rad/s² is confirmed as accurate. The discussion highlights the relationship between linear speed and angular acceleration, clarifying that the acceleration can indeed be lower than the initial speed. Overall, the calculations and approach to solving the problem are validated.
G-reg
An automobile traveling at 30.0 km/h has tires of 85.0 cm diameter.
(b) If the car is brought to a stop uniformly in 15.0 complete turns of the tires (without skidding), what is the magnitude of the angular acceleration of the wheels?
(In part a I found the angular speed to be 19.6 rad/s
(w^2 - wi^2)/(2 * change in theta) ??
-wi^2/(2 *(2* 15pi) = angular acceleration
I'm super lost and would appreciate any help at all. I just need a pointer in the right direction!
Your formula is correct. Check your ωi.
I know that my wi is correct though..
Is there another way to solve this problem maybe?
Well, would the answer 2.038rad/s^2 make sense?
Because that's what I got for my answer but I wasn't expecting the acceleration to be that much slower than the speed
Your answer is correct.
Ok thank you so much!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
