Rotation by matrix multiplication -- confirmation please
The discussion revolves around a rotation matrix and its application to a general point in 3D space, specifically focusing on the transformation of coordinates through matrix multiplication. The subject area involves linear algebra and rotational transformations.
  • Participants discuss the transformation of coordinates using the provided rotation matrix, with some questioning the interpretation of "a general point." There are inquiries about the relationship between the matrix and Euler angles, as well as the implications of the rotation on the axes involved.
The discussion is ongoing, with participants offering insights into the nature of the rotation and its effects on the coordinates. Some guidance has been provided regarding the interpretation of the rotation matrix, but multiple interpretations and clarifications are still being explored.
There is mention of a need for further clarification on the problem statement and the definition of "a general point." Participants are also considering the implications of the rotation in both radians and degrees, as well as the subsequent questions related to the rotation matrix.
Jamie2020
Matrix Rotation
0 1 0
1 0 0
The below matrix represents a rotation.
0 0 -1
0 1 0
1 0 0
Im trying to obtain the general point (x y z) when rotated by the above rotation matrix? So visited https://www.andre-gaschler.com/rotationconverter/ entered the above figures and not sure which entry would be x y z but assume it would be Euler angles (radians) - Could anyone confirm if this would be correct?
Thanks
If you are asking how your coordinates transformed, then you do a matrix multiplication of that with your (x,y,z) column vector and see the result.
Sorry not sure i fully understand what your asking me to do? I thought the result was on that link i provided or are you asking me to a particular area?
Hi,
Not clear what you mean with 'a general point' in the context of (rotation) matrices.
Your matrix swaps x and z and leaves y unchanged. A positive z ends up pointing in a negative x direction.
A little sketch shows that it is a rotation of the xz plane where the x-axis rotates over an angle ##\pi\over 2## towards the z axis.
General point is what's written on my paper.
So i assume the answer would be x: 0, y: -1.5707963, z: 0
I can't see your paper from here :smile:
That would be a way to describe the rotation: around the y-axis over ##-{\pi\over 2}## (i.e. in mathematically negative direction: clockwise as seen from the tip of the vector looking towards the origin.
So changing the above link to degrees would give x: 0, y: -90, z: 0. Unfortunately i copied the question as is so i may need to seek further clarification.
The next 2 related questions are
Next bit is to fill the gaps: The rotation matrix represents A rotation of _________ degrees about the ______ axis.
(I think the first gap is -90 and y (axis)
and
Calculate the single rotation matrix that represents two applications of the above rotation matrix
which i would look into next but not sure if that sheds any light on the first question?
Can you post the full and complete poblem statement ? It is still totally unclear to me what exactly is asked of you (and what you have edited or filled in yourself).
Is 'a general point' actually in the problem text ? Or in the preceding chapter in your textbook or course notes ? If so, how is it defined ?
Why would you want to do such a thing ?
Now come the Next bit , apparently litterally copied:
I agree with your reply.
Two approaches:
Do you know how to multiply two matrices ?
If you made a sketch of the first rotation, can you visualize the result of a repeat ?
  • · Replies 35 ·
