Rotation of Disc: Calculating Angular Velocity
  • Thread starter Thread starter thereddevils
    Disc Rotation
A uniform circular disc with a mass of 10 kg and a radius of 0.2 m experiences a tangential force of 10 N for 10 seconds. The moment of inertia is calculated as I=1/2 mr^2, leading to an angular acceleration of 10 rad/s². Using the rotational kinematics formula, the angular velocity is calculated to be 100 rad/s. However, there is a discrepancy as the provided answer is 10 rad/s, which is deemed incorrect based on the calculations. The discussion concludes that the original calculations appear to be accurate given the parameters provided.
thereddevils
A uniform circular disc at rest has mass 10 kg and radius 0.2m. When a force of 10 N is applied tangentially to the disc for 10s, calculate the angular velocity. Given the moment of inertia, I=1/2 mr^2
Using rF=I(alpha) , alpha = 10 rad/s^2 after substituting r=0.2 , m=10 , F=10
Then, using the rotational formulas,
w = w0 + at (w is meant to be omega)
w = 0+ (10)(10) = 100 rad /s
but the answer given is 10 rad/s .
Your answer is correct. Unless you've copied the given information incorrectly, the answer given is wrong.
This is the working of the answer.
Iw=rt
where I, the moment of inertia, w=angular velocity, r= the radius, and t the time.
and from here, the angular velocity is evaluated. I haven't seen that formula before.
Yeah, your answer is right given that the info is correct
\omega=\frac{2F}{mr}t
