Rotation of Earth relative to a distant star
The problem involves understanding the rotation of the Earth relative to a distant star, specifically how many times the Earth rotates on its axis in one year compared to the apparent motion of the Sun. The context is rooted in astronomy and the mechanics of celestial bodies.
  • Participants discuss the fixed nature of stars and the Sun, and how Earth's rotation and orbit affect the perceived motion of distant stars. There are considerations about the relationship between the Earth's rotation and its orbit around the Sun, as well as the implications of treating distant stars as effectively at infinity.
The discussion is ongoing with participants exploring different conceptual approaches. Some guidance has been offered regarding the relationship between Earth's rotation and its orbital motion, and there is an acknowledgment of the need to visualize the problem through diagrams.
Participants are considering the implications of the Earth's movement around the Sun and how this affects the apparent position of distant stars, as well as the assumption that the stars and Sun can be treated as fixed points in this scenario.
Sara Samuel
On the Earth the Sun appears to rise and set about 365 times in one year. During the same 365 days, how many times does the Earth rotate on its axis relative to a distant star (a star beyond the Sun and out of our solar system)?
Think you should at least think of the stars and the sun fixed. Now the Earth moves around the sun while it rotates. There is 360 degrees in one rotation, but 365 rotations in a year, however, since the Earth moves around relative to the sun, the position of the distant star would change over time.
So what you need to do, is to figure out how the distant star moves relative to the sun - seen from earth. You should find, that the star arrives a few minutes later relative to the axis of the Earth each day compared to the sun, due to the Earth rotating about the sun.
In the end, your answer should actually be, what explains, why we count 365 days per year.
hjelmgart's method is fine, but you will find it a little easier if you treat the distant star as effectively at infinity.
Or draw this diagram:
- sun and Earth at some instant, Earth shown as a circle
- 'another' Earth after moving an angle theta around the sun
- mark the position on Earth where the sun appears overhead on each of the two Earth's
If exactly N days have elapsed between the two Earth positions, that will be the same physical location on earth. What angle has the Earth rotated through on its own axis?
Hint: you will need to know the relationship between the direction the Earth spins on its own axis and the direction in which it orbits the sun.
Thanks a lot!
  • · Replies 0 ·
  • · Replies 40 ·
  • · Replies 23 ·
