Rotation within a vacuum vs rotation with a pressurized environment.
  • Context: Undergrad
  • Thread starter Thread starter BAUCE
    Rotation Vacuum
The discussion revolves around the effects of a pressurized environment on the rotation of objects, particularly in the context of stopping a spinning object. Participants explore theoretical implications and practical applications related to rotation in both vacuum and pressurized conditions, with a focus on space debris management.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests that an object spinning in a vacuum could theoretically spin indefinitely, while in a pressurized environment, it would slow down. They inquire about calculating the time it would take for an object to stop rotating in such an environment.
  • Another participant questions the method for achieving the fastest stopping time, proposing the possibility of changing the shape of the object.
  • A further contribution discusses the challenge of capturing space debris, suggesting that instead of directly grabbing it, one could surround it and pressurize the space to stop its rotation.
  • One participant expresses confusion about the practicality of surrounding debris with a pressurized environment to stop its rotation.
  • Another participant counters the idea of using a pressurized environment to stop rotation by referencing the conservation of momentum, questioning the understanding of this principle among participants.
Participants exhibit disagreement regarding the feasibility of using a pressurized environment to stop rotation, with some questioning the logic behind the approach and others emphasizing the conservation of momentum as a limiting factor.
The discussion includes assumptions about the behavior of objects in different environments and the implications of physical laws such as conservation of momentum, which remain unresolved.
BAUCE
common sense tells me that if an object can remain spinning in the vacuum of space for eternity, than placing that same object within a pressurised environment will cause the object to slow to a stop. is there a way for me to calculate the time in which it would take an object to stop rotating within a pressurised environment? the goal would be to achieve the fastest time in stopping an object from spinning.
By what means? Changing the shape of the object?
thinking along the lines of trash in space. in order to reach out and grab a piece of debris, either it has to stop spinning, or the rotation must be matched. my thought is that rather than 'grabbing' it, surround it and pressurise the space around it so to stop the rotation.
Sorry, but this doesn't make any sense to me. Why would you do it?
That won't work because of conservation of momentum. We don't know your background. Do you understand "because of conservation of momentum" ?
  • · Replies 60 ·
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 35 ·
